pyramid rectangle size
does anyone have the dimensions for the rectngular dimensions of each level, i know the top one, but the other two are very difficult to decipher in the field drawings?
Re: pyramid rectangle size
Through rough calculations our team has found that the top square rungs of the pyramid will create a 30x30 inch square. We have not discussed the middle set of rungs though.
Trying to figure out the same thing right now. I'll post them as I go.
EDIT: Top: 25.25 x 25.25 from centerline to centerline of the tubes. Middle: 49.13 x 49.13 centerline to centerline. Bottom: 73.63 x 73.63 centerline to centerline. EDIT: I'm not sure if these are exactly right, it's hard to tell if the dimensions for the base are for the centerline, inner or outer. Last edited by EricDrost : 05-01-2013 at 17:35. |
check out the first couple pages of the [2013 Team Drawings] look at the length of each segment, make a square.
bottom is 73.02 long pipes middle is 48.57 long pipes top is 24.25 long pipes |
thank you very much
