Go to Post I've be addicted for 15 years. Tried to quit but failed. - Gdeaver [more]
Unread 05-01-2013, 19:29
kpbot kpbot is offline
FRC #4749
kpbot is an unknown quantity at this point
Assisting a Climb
In the video, it seemed a robot helped an alliance partner climb the pyramid. But by this rule, I'm guessing that is not allowed?
G33 A ROBOT may only be supported (fully or partially) by another ROBOT if one of the ROBOTS is in contact with a PYRAMID. Violation: If extended, strategic, or repeated, TECHNICAL FOUL.
(emphasis mine)
Thoughts?
Unread 05-01-2013, 19:30
Taylor's Avatar
Taylor Taylor is online now
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Team Role: Teacher
Re: Assisting a Climb
In the animation, Dozer was in contact with the pyramid.
Hi!
Unread 05-01-2013, 19:32
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
The video is not official; the rules are.
That said, the part you quoted gave an exception - if one of the robots is in contact with the pyramid.
(since 2004)
Unread 06-01-2013, 03:24
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
Rookie Year: 2010
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
Like many others I am trying to guess at the intent of G33.
One thought is that you can have 1 alliance member drive up and touch the pyramid and a second get off the ground by driving on top of them and touching the pyramid (yay - 10 points!)
A second and IMO more interesting thought is whether you can piggy back another alliance member on top of your robot and carry both up at once (we can use 10 bajillion motors so it is feasible). The concern is whether or not the carried robot has to touch the pyramid on its way up. As the rules are written now, it appears the carried robot would have to touch the pyramid on its way up.
My guess is that you cannot get to the top and lower something down to hoist up an alliance mate.
Curious on your thoughts! I think it would be cool if they allowed carrying
-matto-
Unread 06-01-2013, 03:30
Johnbot's Avatar
Johnbot Johnbot is offline
Es Brokein!
AKA: John Westhoff
FRC #4791 (Pandroids)
Rookie Year: 2010
Johnbot is just really niceJohnbot is just really niceJohnbot is just really niceJohnbot is just really niceJohnbot is just really nice
-matto-
If I understood the rules correctly, the robot you carry up would have to touch each rung, as it must sequentially be in each zone, and you are only in a zone if you are touching part of the pyramid in said zone.
Edit: If you lower something down, then your robot is technically getting taller, and you could only lower it 84? inches from the top of your robot.
2011-2014 - FRC 2607 - Student
2012-2012 - FLL 2249 - Coach
2015- ???? - FRC 4791 - Mentor
Unread 08-01-2013, 13:09
Redo91's Avatar
Redo91 Redo91 is offline
AKA: Justin
Redo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of light
I think the clarification that needs to be made is whether you need to be in contact with the pyramid or not for it to be considered a climb. If it is clarified in the manual already, could someone point me to it's location?
Team 1296-Full Metal Jackets
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
Unread 08-01-2013, 13:16
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
Rookie Year: 2011
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
If the floor under the pyramid counts as part of the pyramid (zone 0) when climbing, wouldn't that also imply that it counts as part of the pyramid when supporting another robot?
Or is it more quantum, being both part of the pyramid (for climbing) and not part of the pyramid (for supporting)?
Maybe it's Schrödinger's floor.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 08-01-2013, 13:53
ptkunapuli478 ptkunapuli478 is offline
FRC #0341 (Miss Daisy)
Team Role: CAD
ptkunapuli478 is an unknown quantity at this point
I don't believe that the floor is considered part of the pyramid in regards to climbing because there are no real field structures on level 0. Our team's understanding of the rules is that a robot (say, robot A), that is fully supported by the pyramid (i.e. hanging on its own), can help support another robot (robot B), which is being partially supported by Robot A.
In terms of the idea of carrying another robot up the pyramid, i think it would still be rendered an illegal climb because that robot is not being directly supported by the pyramid. Even if it were, I predict that refs would call that illegal because the second robot is indirectly in contact with non sequential rungs on the pyramid.
Unread 08-01-2013, 14:53
vikesrock777 vikesrock777 is offline
Georgia Tech RoboJacket
AKA: Casey O'Connor
FRC #5332 (Toaster Tech)
vikesrock777 will become famous soon enough
I feel that you have to regard the floor as part of the pyramid. If it's not part of the pyramid, than it becomes hard(impossible?) to contact the pyramid at level 0 for the sake of a legal climb by the rule in 3.2.4.2
A ROBOT has CLIMBED its PYRAMID if it contacts the PYRAMID in
A. sequential order (Level 0, 1, 2, 3) during ascent and
B. no more than two (2) Levels simultaneously.
I don't see a rule dictating a necessity to be supported by the pyramid to be considered for a scored hang, though I may be missing it.
When it comes to lifting a robot up with you, I don't think it would violate the non-sequential rungs rule by indirectly being in contact with another robot touching a higher rung. I would think this contact wouldn't be transitive, but I admittedly have no rule I can find backing up this statement.
