Go to Post If you pay attention to every nut job on ChiefDelphi, you'll never reach a decision. - JesseK [more]
Unread 05-01-2013, 21:11
ehfeinberg's Avatar
ehfeinberg ehfeinberg is offline
AKA: Evan
FRC #0449 (Blair Robot Project)
Rookie Year: 2011
ehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant future
Warped Discs
Just a PSA to everyone,
Every Ultimate players worst nightmare is warping their discs! When a disc is warped, the disc is no longer circular and the rim is no longer flat. This will cause the disk to wobble in flight. A warped disc will also not fly strait.
Discs become warped when they hit a hard surface (a wall, a goal, a robot driving over it). In Ultimate this usually never happens because we play on grass. Unless you knife the disc or fall on it (which Ultimate players would never do), it is hard to warp a disc. However, in Ultimate Assault where every missed shot goes strait into a hard back board, I would not be surprised if most if not all discs become warped over the course of a few matches.
Sadly, this is unavoidable and everyone is just going to have to deal with it. I wish the GDC made rules to prevent teams from intentionally warping discs, but it would still not prevent all the warping of discs.
If you do find that your disc becomes warped, a simple way to unwarp a disc is by placing it on a flat surface and taping the edge of the disc lightly in a circle. If when you tap the disc you find it makes a noise and wobbles, you have found where the disc is warped. You can then bend the disc in the same place you found the warp to attempt to unwarp the disc. Although you can never completely unwarp a disc, by doing this you can greatly improve how long your discs will last before you have to retire them.
Because the discs for Ultimate Assault are 180 grams, not 175, like a normal regulation disc, you can't just go to the store and buy any old disc. (Although the 5 gram difference doesn't seem like much, there is a considerable difference in how the two discs fly).
With 100 something discs on the field at a time, I wouldn't be surprised if they burn through well over 400 discs per competition. It's a shame that they are all junk Whammo discs so they are not even worth taking home.
“They’ve done studies, you know. 60 percent of the time, it works every time.” — Brian Fantana
"You miss 100% of the shots you don't take." - Wayne Gretzky
"Simplicity is the ultimate form of sophistication" - Leonardo da Vinci
Unread 05-01-2013, 21:32
Joon Park's Avatar
Joon Park Joon Park is offline
Joony13
FRC #0639 (Code Red Robotics)
Team Role: CAD
Rookie Year: 2010
Joon Park has much to be proud ofJoon Park has much to be proud ofJoon Park has much to be proud ofJoon Park has much to be proud ofJoon Park has much to be proud ofJoon Park has much to be proud ofJoon Park has much to be proud ofJoon Park has much to be proud of
Re: Warped Discs
I was worried about this as well, but this would only matter to the teams that actually plan to be spinning the disc over a distance.
Although I don't think it'll really be as much of a factor as ball degradation was last year.
Team 639: Code Red Robotics
2013 Robot: The Red Raptor
2013 Archimedes Division
2013 Buckeye Regional Winner
2013 Buckeye Spirit Award
2013 FLR Spirit Award
2012 Newton Division Finalist
2012 FLR Semi-Finalist, Engineering Inspiration Award
2012 DC Quarter-Finalist, Industrial Design Award
2011 FLR Quarter-Finalist
2011 Boston Quarter-Finalist, Imagery Award
2010 FLR Quarter-Finalist, Innovation in Control Award
2010 Philladelphia Semi-Finalist, Gracious Professionalism Award
Unread 05-01-2013, 21:40
Ernst's Avatar
Ernst Ernst is offline
Ernst
AKA: Ernst
FRC #1732 (Hilltoppers)
Rookie Year: 2011
Ernst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond repute
Re: Warped Discs
The G14 Bluetext says
DISCS are expected to undergo a reasonable amount of wear and tear as they are
handled by ROBOTS, such as scratches and occasional marks. ROBOTS that gouge,
tear off pieces, or routinely mark DISCS will be considered in violation of G14.
It doesn't mention anything about warped disks. I hope that the GDC clarifies this rule to prevent the intentional warping of disks.
Unread 05-01-2013, 22:04
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Re: Warped Discs
Not very GP to intentionally and significantly shorten the usable lifespan of game pieces on the field.
Unread 05-01-2013, 22:05
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Warped Discs
Can you elaborate on your experience in the flight differences between a 175 disk and a 180 disk? Are they different sizes as well?
Also:
2.2.10 The DISCS
The DISCS are Wham-O part number 53214 (custom colored Red, White, or Blue) and have a diameter of 10 5/8 in., a height of 1 1/4 in., and a weight of 180 ± 5 grams
(emphasis mine) So these could weigh as little as 175 g
Unread 05-01-2013, 22:25
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Rookie Year: 2010
slijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to behold
Re: Warped Discs
Alsoemphasis mine) So these could weigh as little as 175 g
I tossed one in school today, but didn't notice much of a difference - take that with a big grain of salt though.
There are a number of differences between the FIRST disc and a regulation Ultimate disc. Regulation discs are 10.75" wide, 1" thick, and as pointed out, 175g - which, obviously, is also a nominal figure. The more noticeable difference, however, is that the FIRST discs are made of a much more brittle and "hard" plastic, so to speak, and seem to have been produced with a different mass distribution (denser around the rim than the center, as opposed to the regulation disc).
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 05-01-2013, 23:18
knuckleduster knuckleduster is offline
AKA: Jack Manning
FRC #0058 (The Riot Crew)
Rookie Year: 2007
knuckleduster is an unknown quantity at this point
Re: Warped Discs
I took out the good ol' scale today and weighed my KoP disks and got anywhere from 176-178 grams depending on the disk (comes with 4 btw). When I weighed a disk I had on hand i got 176g and it is almost the exact dimensions of the other disk. The only bad news is that it was from a set of misprints and will probably never have any other duplicates handy.
Unread 05-01-2013, 23:45
slijin's Avatar
Pockets
AKA: Samuel Lijin
Rookie Year: 2010
Re: Warped Discs
Also, on second thought - I don't see these Whammos warping, I see them snapping in half and a million splinters. The plastic feels rather brittle.
Unread 05-01-2013, 23:48
ehfeinberg's Avatar
AKA: Evan
Rookie Year: 2011
Re: Warped Discs
I will gladly test that by chucking the Frisbee's at a wall. Should be fun
lorem3k's Avatar
lorem3k lorem3k is offline
1 + 1 = 0 (in Z/2Z)
AKA: Andy D.
FRC #1482 (Bishop Grandin Ghosts)
Rookie Year: 2011
lorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to behold
Re: Warped Discs
Also: (emphasis mine) So these could weigh as little as 175 g
Weight specifications for any particular regulation disc could conceivably allow for variations (for example, a disc rated 175g ± 5g) that would place it outside of the FRC spec.
Boo! Bishop Grandin High School / GM Canada / Tenaris
2013 Western Canada - Quarterfinalists (thanks 288/4719) / 2012 GTR West - Quarterfinalists (thanks 188/1075) / 2011 GTR East - Regional Winners (thanks 1114/1503)
Unread 06-01-2013, 00:01
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Re: Warped Discs
2.2.11 The DISCS
The DISCS are Wham-O part number 53214 (custom colored Red, White, or Blue) and have a diameter of 10 5/8 in., a height of 1 1/4in., and a weight of 180 +-5 grams.
Rules say that it'll be anywhere between 175 and 185g. 176-178 seems right on par with what FIRST has specified.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
