Go to Post Michigan is all about tough love. If you can make it there you can make it anywhere. - Koko Ed [more]
Unread 06-01-2013, 11:46
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
Question about 54" vertical cylinder rule
Is the 54" cylinder defined as vertical relative to the floor, or vertical relative to the robot? Because when climbing, the robot could be taller than 54" and be tilted sideways, in which case it would exceed the boundary if the cylinder was always oriented relative to the ground.
Unread 06-01-2013, 11:54
cgmv123's Avatar
cgmv123 cgmv123 is online now
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Re: Question about 54" vertical cylinder rule
I can't speak to this year's rules, but the GDC's answer to questions like this in the past is that dimension rules are all relative to the robot.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 06-01-2013, 12:43
Recla1mer 329's Avatar
Recla1mer 329 Recla1mer 329 is offline
AKA: CJ
FRC #0329 (Raiders)
Team Role: Mechanical
Recla1mer 329 is an unknown quantity at this point
the orientation of the 54" changes as the orientation of the robot changes. also worth noting: the 54" circle that your robot must stay in changes as you extend appendages.
