Go to Post At the end of the day, it really isn’t about the awards. - JesseK [more]
Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Unread 06-01-2013, 11:55
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
Team Role: CAD
Rookie Year: 2011
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
Climbing Mechanism Ideas
There's already a thread for shooter ideas so what are you guys thinking in terms of climbing?
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
Unread 06-01-2013, 12:03
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Team Role: Coach
Rookie Year: 2010
Robby Unruh will become famous soon enough
Re: Climbing Mechanism Ideas
My team has been prototyping something along the lines of a "bike peddler" design.
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 06-01-2013, 12:08
Nominal Nominal is offline
FRC #2996
Nominal is an unknown quantity at this point
One of my teams ideas was to have a conveyor belt like mechanizm with claws to grasp the bars
Unread 06-01-2013, 12:15
scott1363 scott1363 is offline
FRC #0353
scott1363 is an unknown quantity at this point
I have the question regarding the rules and the animation.
During the animation, they show a robot scooting under the bars, being at level 0 - the ground, grabbing the second level then lift up and touching the first level.
This either violates the rule about skipping a level or if there is some sort of contact with level one prior to touching level 3, it violates touching more than 2 levels at a time.
Am I wrong?
Thanks.
Unread 06-01-2013, 12:17
AKA: Jesse Gibson
Team Role: CAD
Rookie Year: 2011
The game animations do not always agree with the rules. Although, I do believe that robot jumped up onto the first level before hooking onto the second.
2011 - Logomotion
Unread 06-01-2013, 12:29
BAM BAM is offline
FRC #2425
BAM is an unknown quantity at this point
Am I wrong?
Thanks.
Unfortunately yes. If you look closely you can see the robot perches itself on level one, and THEN uses hooks itself to level two.
Unread 06-01-2013, 12:51
TVwazhere's Avatar
TVwazhere TVwazhere is offline
Unregistered User
AKA: TomTom
FRC #0020 (Rocketeers)
Team Role: CAD
TVwazhere can only hope to improve
Yeah. In the animation, it bounces before grabbing the second bar.... hence leaving level 0, being suspended momentarily on level one before grabbing level 2. I had that question originally but looking back on it it just barely avoids the penalty
"Well there's your problem!" -Mythbusters
"It's Dope" -Will.I.Am, Jan 9th, 2011 FIRST Locomotion Kickoff
"Design Thrice, Measure Twice, Cut Once"- Tom Tom
"If your life was a Disney film, then this is the part of the movie where you would break out into song" - Tom Tom
Unread 06-01-2013, 13:12
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
But the rule states that a legal climb is when the robot contacts the pyramid sequentially. The pyramid does not include the airspace, or you will never have a "legal climb". If the air space was considered part of the pyramid in that level, to get to suspended in the 1st level, your hook would intrude into the 2nd level air space. That would mean that it was not a legal climb because you are in 3 levels at one time (0, 1, 2). But that is the wrong interpretation. Airspace is not part of the pyramid of the corresponding level; but it is still part of the "level" when counting points. The pyramid is only the steel structure.
A ROBOT has CLIMBED its PYRAMID if it contacts the PYRAMID in
sequential order (Level 0, 1, 2, 3) during ascent and
no more than two (2) Levels simultaneously.
If a CLIMB is considered unacceptable (e.g. a ROBOT has touched non-adjacent Levels or more than two (2) Levels at a time), a Referee will indicate a rejected CLIMB by turning the offending ROBOT’S PLAYER STATION LED strings yellow. The ROBOT will be ineligible for CLIMB points unless and until it begins a new CLIMB from the floor, Level 0.
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
Unread 06-01-2013, 13:59
TVwazhere's Avatar
Unregistered User
AKA: TomTom
Team Role: CAD
That makes sense, Otherwise any robot thats over 60" tall near the pyramid would be in violation of that rule.... They really should clarify slightly more.
Unread 06-01-2013, 14:28
moogboy's Avatar
moogboy moogboy is offline
Wiggling With Experience
AKA: Bubba
FRC #3175
Rookie Year: 2011
moogboy is a jewel in the roughmoogboy is a jewel in the roughmoogboy is a jewel in the roughmoogboy is a jewel in the rough
We've come up with a few designs already. One has a groove going through the whole underside of the robot and a pair of treads/belts/whatever on each side of the groove. There would be at least two sets of two grabbers/hooks/grappling devices, preferably parallel to one another at two different points along the belts. We would drive up to the corner of the pyramid, push the robot up the corner pole until the lifter can engage, and turn it on, hoisting the robot up off the ground and up the poles.
Another thought was to have (essentially) two of these, one at the front and one at the back of the robot: http://www.youtube.com/watch?v=Y94Yhm1dhv0 Obviously it would be highly modified and adapted with better wheels and so on, but the idea would be that the first one would pull the robot up to the bottom of a level, then kind of disengage and retract, letting the second one push the robot up enough for the first to re-engage, which would let both be used to pull the robot up.
those two were based on climbing up the corners. We had one idea that would be based on climbing the horizontals. Basically, that one had three arms. One would grab the horizontal and pull the front of the robot up. Then the other two arms would grab onto that bar for stability while the third pulled the robot up to the next level and so on.
Hope that was of some help.
I'm Bubba. I make noise, sometimes it comes out as music, and I love robots.
Unread 06-01-2013, 14:35
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
Team Role: Teacher
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
I like your idea ,how would you keep the 120lb robot from rotating around the pole?
Faridodin "Fredi" Lajvardi KD7WKD
Unread 06-01-2013, 14:40
AKA: Ledge
Team Role: Teacher
Funny when I type robot climbing monkey bars in You Tube, I get nothing....
I did find this though when I typed robot climbing pole
http://www.youtube.com/watch?v=0HEn-fWKcqc
Unread 06-01-2013, 14:45
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
http://www.youtube.com/watch?feature...fySkGA#t=67 s
http://www.youtube.com/watch?v=OtP0BspnSjY
May be a similar principle might work. But that's just throwing any legality out the window.
Unread 07-01-2013, 10:03
J.Warsoff's Avatar
J.Warsoff J.Warsoff is offline
BECAUSE SCIENCE
AKA: Jared Warsoff
FRC #1676 (The Pascack PI-oneers)
J.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond repute
Take a look at our Breakaway robot, Weeble. Rather simple mechanism, grappling hook and winch.
http://www.flickr.com/photos/team1676/5199271926/
"I reject your reality, and substitute my own!" -Adam Savage
Check me out on Twitter or Facebook
Acoustical Engineering & Music major at the University of Hartford / Hartt School of Music Class of 2017
  #15   Spotlight this post!
Unread 10-01-2013, 14:44
Night_Shade's Avatar
Night_Shade Night_Shade is offline
AKA: Mollye Coday
FRC #2389 (Oklahoma Storm)
Team Role: Mechanical
Rookie Year: 2013
Night_Shade is an unknown quantity at this point
We are working on our robot design ideas. I was wondering if this idea would work.
Our idea is to have three arms. Two are going to grab onto the bar while the third keeps it in place. We want to get to the third level then dump four of the color frisbees in. Any ideas to help with the design? We need an idea for how we are fully going to climb the tower.
Night_Shade
