Go to Post Every team in FIRST can make this choice. Be positive, help others, and work like a maniac behind the scenes. This approach will bring you joy and satisfaction, whether you win or not. - OZ_341 [more]
Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Unread 07-01-2013, 20:41
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
Team Role: Coach
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Re: Climbing Mechanism Ideas
I'm worried. I see a lot of posts from folks who are misinterpreting the rules, and I'm worried that we'll see a host of unusable robots at the regionals. Yes, there is need for clarification from QA about whether the airspace directly above the tops of each rung constitutes a new zone, but I think the clear intention of the rules is that we find a solution that only allows us to touch (or exist in) two zones at a time. We therefore can't slide up the rungs, or use a hooked conveyor belt, or ski up them. Clearly, it would be much easier if you could balance on two rungs as you reach for a third, but you can't. you will have to freely swing from each rung as you try grasp the next one up.
Not trying to be a party pooper. I really do want to see some cool solutions, but I have been to enough events to have seen the heartbreak of teams who misread the rules, and have to play defense as a fallback, or completely rebuild on game day.
Unread 07-01-2013, 21:16
SteveGPage's Avatar
SteveGPage SteveGPage is offline
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
According to the manual:
A ROBOT has CLIMBED its PYRAMID if it contacts the PYRAMID in
A. sequential order (Level 0, 1, 2, 3) during ascent and
B. no more than two (2) Levels simultaneously.
If a CLIMB is considered unacceptable (e.g. a ROBOT has touched non-adjacent Levels or more than two (2) Levels at a time), a Referee will indicate a rejected CLIMB by turning the offending ROBOT’S PLAYER STATION LED strings yellow. The ROBOT will be ineligible for CLIMB points unless and until it begins a new CLIMB from the floor, Level 0.
... emphasis mine ...
I agree there needs to be clarification from QA, but I see nothing that indicates the "air" in a level is "contacting" or "touching" the pyramid. So I'm not clear how such posts are "misintrepreting" the rules. Please show the rule or part of the manual that suggests your intrepretation.
Thanks!
Steve
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2017: Southwest VA, Northern MD, Chesapeake District Championships, Championships
Unread 07-01-2013, 21:49
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
Team Role: Coach
Rookie Year: 2007
Siri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond repute
Send a message via ICQ to Siri
Touch and "exist in" are not synonyms. The sequential & simultaneous contact rules are about just that (contact). Whether the airspace above the rung constitutes the next level (which it does) is immaterial for this purpose, because contact is based on the steel, not the air. Skiing, driving, hooking, etc are only illegal if they contact the steel in the next level before losing contact with n-2. I don't see anything in these posts that indicated teams don't understand this?
Unread 07-01-2013, 22:10
mrnoble's Avatar
teacher/coach
Team Role: Coach
As I understand it, in order to ski up the rungs you must be supported by rungs 1 and 2, touch rung 3 and release rung 1, in that order. That is my concern; in order to meet the requirements of the rules, you must NOT touch rung 1 when you begin touching rung 3. That leaves you balancing on only rung 2. I don't see how that would work, but maybe I'm missing something.
Unread 07-01-2013, 22:15
mrnoble's Avatar
teacher/coach
Team Role: Coach
I'm also taking into account that in order to score 10, 20 or 30 points, the robot must exist entirely above the plane that defines each zone. I don't think (from my reading) that a robot could, for instance, grab the first bar, then the second, release the first, grab the third, release the second, and be hanging with the wheels below the plane of first (or second) bar, and still get 30 points, regardless of whether the robot is touching any but the third bar.
Unread 07-01-2013, 22:45
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Donut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond repute
Originally Posted by jason701802 View Post
What if you lift them up such that they never touch anything other than level 0?
Then the robot would not have performed a proper CLIMB, since it has not made contact with the pyramid. This results in no score.
FRC Team 498 (Peoria, AZ), Student: 2004 - 2007
FRC Team 498 (Peoria, AZ), Mentor: 2008 - 2011
FRC Team 167 (Iowa City, IA), Mentor: 2012 - 2014
FRC Team 2662 (Tolleson, AZ), Mentor: 2014 - Present
Unread 07-01-2013, 22:26
ewrado's Avatar
ewrado ewrado is offline
FRC #0842
ewrado will become famous soon enough
this is cool
http://youtu.be/kqGOwqWBV-E
Unread 06-01-2013, 15:00
AhAhPatel's Avatar
AhAhPatel AhAhPatel is offline
FRC #1261 (The Peachtree Ridge Robolions)
Rookie Year: 2010
AhAhPatel is an unknown quantity at this point
what do you mean by bike peddler design?
Unread 07-01-2013, 01:35
DampRobot's Avatar
DampRobot DampRobot is offline
Physics Major
AKA: Roger Romani
FRC #0100 (The Wildhats) and FRC#971 (Spartan Robotics)
Rookie Year: 2010
DampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond repute
Any teams had any luck prototyping "minibot climber" types? I'm talking about something that rides up the diagonals of the pyramids on wheels, hanging on somehow.
The mind is not a vessel to be filled, but a fire to be lighted.
-Plutarch
Unread 07-01-2013, 03:38
Adam.garcia Adam.garcia is offline
Design Mentor
FRC #0004 (Team 4 Element)
Rookie Year: 1997
Adam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really nice
For this, I've been thinking of having an articulated 1717 2010-esque lifter that will be able to traverse the corners. Have a latching system on the top, and drive wheels at the bottom. By any chance, does anybody have close up pics of their latching mechanism from that year?
I see that they posted pics of their bot here: http://www.chiefdelphi.com/media/photos/35361
But the only pic that is broken is the one for the latching.
“The object of education is to teach us to love what is beautiful.”
“Never discourage anyone who continually makes progress, no matter how slow.”
Unread 07-01-2013, 13:03
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Rookie Year: 2010
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
1717 Used a gas spring to lift themselves up. This was an excellent idea because even if they grabbed the tower at the last second, the robot would still go up the tower even after the robot was disabled. That mechanism wouldn't work this year as it reacted against the top surface of the tunnel.
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 07-01-2013, 13:42
Gir_450's Avatar
Gir_450 Gir_450 is offline
Sparky
AKA: Eric
FRC #1566 (Ammoknights)
Team Role: Electrical
Rookie Year: 2010
Gir_450 is on a distinguished road
Send a message via Yahoo to Gir_450
Ok, our team was thinking of an extending hook that would grab the 3rd rung and winch us up as we drove up the side of the pyramid and stopped at possibly the 20 point zone. Would this be against the rule that says we would need to climb up sequentially?
"And people say im slow.....wait a second, that was an insult!" -Homer Simpson
Unread 07-01-2013, 13:52
Siri's Avatar
Dare greatly
Team Role: Coach
Rookie Year: 2007
Yes. If you grab the 3rd rung while on the floor, you are not climbing sequentially (because the floor is Level 0).
Unread 07-01-2013, 11:33
Rishabhgadi's Avatar
Rishabhgadi Rishabhgadi is offline
Alumni, 1255 mentor
FRC #1255 (Blarglefish)
Rookie Year: 2010
Rishabhgadi is an unknown quantity at this point
That was my initial idea, but you would not reach past the first level because of the notches on the side which stick out about an inch.
  #15   Spotlight this post!
Unread 07-01-2013, 11:39
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
Specifically, the knuckle sticks out quite far on the front, and the gusset extends in the back of the pole, too.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
