Go to Post For some people FRC is an introduction into STEM and just a way to open someones eyes to a world they might not know exist. To other it is a lifestyle that makes crossfit look casual. - IronicDeadBird [more]
Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Unread 07-01-2013, 12:23
amesmich's Avatar
amesmich amesmich is offline
FRC #4638 (Jagbots)
Team Role: Teacher
Rookie Year: 2012
amesmich is an unknown quantity at this point
Re: Climbing Mechanism Ideas
I dont think I read anythign pertaining to this but before a climb could a bot disconnect its drive system and essentially leave it behind to reduce weight and size? Obviously the rio, battery, and control would climb but the drive train abandoned? The whole thing woudl be designed as a quick disconnect.
Unread 07-01-2013, 12:24
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
No
The robot cannot intentionally leave parts behind. G13
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 07-01-2013, 12:46
amesmich's Avatar
FRC #4638 (Jagbots)
Team Role: Teacher
Rookie Year: 2012
Dam I missed that. I wasnt just posting for an answer.
Unread 08-01-2013, 13:05
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
Rookie Year: 2011
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
Originally Posted by Rishabhgadi View Post
That was my initial idea, but you would not reach past the first level because of the notches on the side which stick out about an inch.
You could have a mechanism that grabs onto the notches lift you up just enough that you can then go back to climbing the rail
Unread 09-01-2013, 02:31
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
I've read through this entire thread and i was just confused. Are you allowed to drive into the pyramid and latch onto the second rung and winch yourselves up or do you have to touch the first rung first? Or is it that if you are outside the pyramid and latch onto the second rung and winch your self to victory? Are they both legal? Neither? Please help or at least some clarification.
"Sometimes the questions are
complicated but the answers are simple."
- Dr. Seuss
Unread 09-01-2013, 09:28
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
[I underlined the part I'm responding to.]
This would not be a legal climb (it would get 0 points). Game Manual section 3.1.5.2 says the robot must contact the pyramid levels in sequential order. This proposal would contact level 0 (floor) and 2 (second rung), but not level 1.
If you modify this somehow to make it valid, it would be 20 points.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 09-01-2013, 10:30
vikesrock777 vikesrock777 is offline
Georgia Tech RoboJacket
AKA: Casey O'Connor
FRC #5332 (Toaster Tech)
vikesrock777 will become famous soon enough
To expand on what Cal578 said, you need to make sure you observe both of the rules when performing your climb.
A ROBOT has CLIMBED its PYRAMID if it contacts the PYRAMID and/or the floor (Level 0) in
sequential order (Level 0, 1, 2, 3) during ascent and
no more than two (2) Levels simultaneously.
In order for a legal climb to get to level 2 points, you need to contact sequentially and contact no more than 2 levels simultaneously. This means that you must first contact the pyramid at level one and lift yourself such that you are no longer contacting the floor (level 0). Only then can you contact level 2 and lift yourself into that zone.
Unread 09-01-2013, 12:11
AKA: Gerry
I'm glad vikesrock expanded on what I said. I actually meant to respond to both proposals. I don't know why I only underlined the second. There isn't any difference (from a rules point of view) between climbing inside or outside the pyramid.
Cal
Fairport, NY, USA
Unread 07-01-2013, 15:37
jake517 jake517 is offline
FRC #4294
jake517 is an unknown quantity at this point
Where exactly is the auto zone? My team would like know exactly where on the field your robot can go up to 84 inches?
Unread 07-01-2013, 15:40
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
Rookie Year: 2011
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
Your colored carpet and i believe feeding station, not sure about the latter though
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
Team Role: CAD
Rookie Year: 2011
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
The auto zones are the areas marked out but the long pieces of red and blue tape that cross the fields on the side of the pyramids closest to the center of the field. If you look at the field drawings in the manual, look for the biggest pieces of colored tape. Whenever you are contacting carpet within the zone or are touching the pyramid, you can go to 84".
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
Unread 07-01-2013, 15:57
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
Look what they did a few years back in FTC. Look familar?
http://www.youtube.com/watch?v=ZjEtPgTrYPQ
Unread 07-01-2013, 15:59
AKA: Jesse Gibson
Team Role: CAD
Rookie Year: 2011
Yeah, that was VEX round up. The biggest difference between then and now is that in round up, you could latch on to the top and pull yourself all the way up which is, unfortunately, illegal in Ultimate Ascent.
2011 - Logomotion
Unread 07-01-2013, 16:04
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
That's true , but only grabbing the second rung with s similar technique would get you 10 points.
  #15   Spotlight this post!
Unread 07-01-2013, 16:14
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
Team Role: Teacher
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Ok it took awhile to find, but here is a climbing robot that could climb our pyramid legally
http://robotzeitgeist.com/tag/climbing-robot
Faridodin "Fredi" Lajvardi KD7WKD
