Re: Climbing Mechanism Ideas
-Mike |
i'm an alumni of Team 1108, Panther Robotics and we have our 2nd robot which was apart of the 2004 FIRST Frenzy game. our climbing mechanism is a winch made from the CIM equivalent motor paired with a Dualt drill transmission. this combination was indestructible durring competition and had no problems lifting a 140 lb robot (battery weight included)
Here is our plan that we are trying to flesh out
https://docs.google.com/file/d/0B44T...V0Z0JlM1U/edit Hope it works _____________ |
Ok, I don't mean to picky here, but I just realized what might be a problem. Imagine a hook that fits on the bar. Since the hook is touching the top of the bar, and the middle of the bar, this hook is touching the pyramid in 2 levels.
If you had hooks of any sort that pulled you up with say, something holding you on a lower bar, 1 level, and the one above is hooked on a bar, you are in 3 zones, if only by the quarter inch thickness of the claw......... Any thoughts? Would they be this picky in the rules? Thanks Mike |
Ok are team is at a bit of a standstill on climbing. We realized that our climbing idea won't work because of the rule that says we can't extend outside a 54" cylinder. So we decided to figure out a way to go up the corner legs. Any ideas?
#10
Climbing seems much more difficult than we anticipated. Our strategy put climbing ahead of shooting, but I'm beginning to think that that wasn't the best idea. |
#11
Anyways... No one I've mentioned this too really likes my idea but it goes like this...
I simply use a spring loaded a "jumping" mechanism that would catapult my robot towards the top rung. While in mid flight, the robot reaches out and briefly touches level 1 and 2 in that order, then grasps on to the top rung. I enjoy imagining what would happen if it misses... |
#12
Well, I would say, "Hey, we have bumpers." And I can always install a parachute...
#14
re: "I simply use a spring loaded a "jumping" mechanism that would catapult my robot towards the top rung. While in mid flight, the robot reaches out and briefly touches level 1 and 2 in that order, then grasps on to the top rung."
There are some tough challenges here. The amount of power required to have a 120 lb (150 lb w/battery and bumpers) robot 'jump' ~9' is ridiculous and extremely dangerous. The skill level required to do this and touch the levels and then grasp the top row is outrageously difficult. You're much better off just grabbing the bottom row and picking up an easy 10 points. |
