Go to Post The robots are just vehicles taking kids on a ride to STEMville. - FTC5110 [more]
Unread 06-01-2013, 14:36
Gnome2013's Avatar
Gnome2013 Gnome2013 is offline
Gnomies
FRC #2013 (Cyber Gnomes)
Gnome2013 is an unknown quantity at this point
How Long Should Re-Imaging cRIO Take?
How long should re-imaging the cRIO take? Ours seems to be stuck on rebooting for at least the last half hour.
Unread 06-01-2013, 14:41
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: How Long Should Re-Imaging cRIO Take?
It should only take 5 or so minutes. What is your network configuration?
Unread 06-01-2013, 14:45
Gnome2013's Avatar
Gnomies
I have it connected with the Ethernet cord like it said in the guide, configured the IP address, and turned off the firewall. It recognized the cRIO then I choose the options for Java and said apply.
Unread 08-01-2013, 07:23
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Rookie Year: 2010
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
I have seen this more then once with the imaging taking "hung" a very long time.
If it has been 15 minutes or more I would suggest just killing the process in the task manager (e.g. CNTL/ATL/DEL)
Saw the NI rep do this during the quick build session on Jan 5/2013!
Unread 08-01-2013, 08:33
daniel_dsouza daniel_dsouza is offline
does what needs to be done.
FRC #2449 (Out of Orbit Robotics)
Rookie Year: 2011
daniel_dsouza has a spectacular aura aboutdaniel_dsouza has a spectacular aura about
Ethernet or crossover cable? Unless the cRIO is auto-switching, it will need a crossover cable. Our reimage took all of 2 minutes.
Unread 08-01-2013, 09:45
jwakeman jwakeman is offline
FRC #0063 (Red Barons)
Rookie Year: 2010
jwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nice
Using a 4-slot cRIO we ran into the same problem, stuck on the rebooting cRIO step. Tried it several times, killing it with the task manager after several minutes each time. I was using the pink crossover cable that came in the kit before for use with the camera. Finally we tried connecting to the cRIO through a router (wired..not wireless) and turning the console out dip switch to off and it worked. Had seen this suggestion for the router in a google search, the idea being that Windows can turn off the ethernet port on the PC when the cRIO reboots. We were very happy to see it work but then we weren't sure if it was the router or the console out switch change that made it work. So we turned the console out back on and it still worked. Finally we removed the router, left the console out on (original configuration) and it worked.. So now we are not sure what exactly made it start working.
