Go to Post Amazing what you can find with a quick video and the unlimited power of the internet! - AveryLevin. [more]
Unread 06-01-2013, 16:24
Gadeer Zbedat Gadeer Zbedat is offline
FRC #1946 (Mishka Monster)
Rookie Year: 2012
Gadeer Zbedat is an unknown quantity at this point
Smile Need help in programing the camera Axis point
Hii )
I'm member of team #1946 From Tamra-ISRAEL
This year we should use the camera !! without the camera it's all full of $@#$@#$@#$@#
So ,I need your help guys in programing the camera in C++ language .
{Last year we don't use the camera}
Unread 06-01-2013, 19:13
mprasolov's Avatar
mprasolov mprasolov is offline
Jack of all trades
AKA: Misha Prasolov
FRC #2823 (The Automatons)
Team Role: Student
Rookie Year: 2012
mprasolov is an unknown quantity at this point
Re: Need help in programing the camera Axis point
You can look at our code from last season here
All we did was put this code in our initialization class. (Not the constructor)
Code:
AxisCamera &camera = AxisCamera::GetInstance();
It will build with a warning, but works anyway. Sends feed to dashboard (not the driver station) if you configured the camera correctly. I recall the IP of the camera should end in .11 or something like that.
Unread 07-01-2013, 09:11
Rookie Year: 2012
Should I measur the dimension from the robot to the goal we throw at it the freesbie disc?
Unread 07-01-2013, 11:10
Ido_Wolf's Avatar
Ido_Wolf Ido_Wolf is offline
LabVIEW Addict
AKA: Ido
FRC #2230 (General Angels)
Rookie Year: 2011
Ido_Wolf is an unknown quantity at this point
Generally in its stock settings, the camera's IP is 192.168.0.90. When you connect it to your router (as all rookie teams starting 2012 have to as they don't have a 2nd port in the new cRIO), and set it up properly with the "Setup Axis Camera" tool, the IP would be 10.xx.yy.11 (xxyy=your team number).
If you connect it to the 2nd Enet port of your cRIO though, the IP should be set to 192.168.0.90.
I don't quite understand the question here; you should measure it if you want to use it in your code, obviously. I'm not quite up to task as far as C++ is concerned, but if there's any alternative for WPILib's examples there, you should probably find an example code that shows you how to find the diagonal range from the target. You can use some trigonometry to find out the vertical and horizontal range from the target using the diagonal range and the camera's angle in relation to the target...
(Also, if you want any consultancy in Hebrew, feel free to PM me. Keep in mind that my IDE of choice is LabVIEW though)
Unread 07-01-2013, 11:40
Rookie Year: 2012
you can give me the text of programing it ?? in c++ ??
---->you are from Israel??
