Go to Post the usual Canadian thing - Karthik [more]
Unread 06-01-2013, 19:40
swwrobotics's Avatar
swwrobotics swwrobotics is offline
FRC #2900 (The Mighty Penguins)
Team Role: Mechanical
Rookie Year: 2011
swwrobotics is an unknown quantity at this point
Frisbee throwing idea?
So I found this rule about human interaction with the field:
DISCS may be fed onto the FIELD only under the following circumstances:
A. during TELEOP through the FEEDER SLOTS and
B. during the last thirty (30) seconds of TELEOP over the FEEDER STATIONS.
Emphasis mine - I was wondering if it would be allowed to do that trick where you can throw the frisbee really high so that it comes back towards you, and if this would be an allowable way to score goals with the white discs. Any thoughts on this?
