Go to Post Sooo....in the famous words of Douglas Adams, Don't Panic. - Conor Ryan [more]
Unread 06-01-2013, 20:38
Zach S. Zach S. is offline
FRC #3307 (Luray Robodawgs)
Rookie Year: 2011
Zach S. will become famous soon enough
Moving Servo Motors
For the past three years now me and my team have been trying to set our joystick to be able to move our servos on camera and any other place on bot. Can anyone help me to a) move them with the axis of the joystick or b) press a button to move it to one position?
Unread 06-01-2013, 21:01
Re: Moving Servo Motors
There are a number of good ways of doing this, but perhaps what you want is to identify an initial servo setting, say 90 degrees. Pressing a button adds a delta, say 10 degrees to the number and updates the servo. Perhaps another button will subtract 10. Alternatively, you could use buttons to simply set the number to a special number.
The code for this would look similar to the attached image. Note that I duplicated the case diagrams near it as printing would. They are actually stacked in the code as individual diagrams.
greg McKaskle
Unread 06-01-2013, 21:17
Rookie Year: 2011
Okay, that makes sense, but in the picture, what are the blocks to the right of the button cluster? and the the right of the True? ANd the blue thing above the top most case structure?
Unread 06-01-2013, 21:30
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Originally Posted by Zach S. View Post
me and my team
my team and I
Attached is an example from team358.org
Unread 06-01-2013, 21:31
Sorry about that. I wasn't sure how much LV you knew.
I attached the VI, and you can now show the help window and idle the mouse over each of the nodes to see what they are and what they do.
To answer you questions anyway:
The buttons I was interested in are indexed from the cluster and placed into an array. The array is searched for True to see which is pressed. The node with the magnifying glass is the search. The blue arrow box above the case is called a feedback node and is used to keep values from call to call. This "remembers" the value from last time. The case structure code updates it.
Greg McKaskle
Unread 06-01-2013, 21:32
Rookie Year: 2011
Originally Posted by Ether View Post
my team and I
I have seen and tried that bit of program to no avail.
Unread 07-01-2013, 00:09
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Did you install the servo power jumper on the pins next to the PWM output on the Digital Sidecar?
Unread 07-01-2013, 05:30
Rookie Year: 2011
No. I'm not even sure what that is. Would that be why no servo programming I do ever works?
Unread 07-01-2013, 06:02
Ido_Wolf's Avatar
Ido_Wolf Ido_Wolf is offline
LabVIEW Addict
AKA: Ido
FRC #2230 (General Angels)
Rookie Year: 2011
Ido_Wolf is an unknown quantity at this point
Probably, it happened to us before too. They basically wouldn't receive any input when the jumper is not connected.
As a rule of thumb, when you try to learn how to use a new component you've never used before, I suggest utilizing the appropriate LabVIEW example first, and consulting one of your fellow teammates from the electronics department (or a mentor if no other student knows), as the vast majority of "component not receiving/returning value" issues come from either faulty wiring or missing a certain VI that you wouldn't think of when utilizing it by yourself.
The appropriate example here is "Servo Camera.lvproj", you might want to combine it with the example "Rectangular Target - 2013" and integrate both of them into your code.
(Keep in mind that in my experience, the camera's servos are incredibly unstable and unreliable, especially if you try to use to camera to "home in" on the target rather than an additional point of view for the drivers)
Unread 07-01-2013, 09:05
Software Architect
Each of the three-pin PWM OUT connectors on the Digital Sidecar is accompanied by a 2-pin PWM OUT +V header. The PWM OUT pins are SIG, PWR, and (-). The PWR pin is where a servo gets its power from, but it doesn't actually provide any power until you put a jumper on the +V header pins.
Signs point to "yes".
Unread 07-01-2013, 19:05
Rookie Year: 2011
Thanks for the Vi and jumper note. We added them to our older robot today, and will be trying out my code tomorrow. You guys solved a three year old question for us!
Unread 23-01-2013, 11:11
Rookie Year: 2011
I finally had the chance to deploy our code and with adding the jumpers it worked flawlessly! We can now move our servos with axis and buttons, thanks you guys!
Head of Computer Systems and Programming of Team 3307
