Go to Post Once you have reached overkill, more is not useful. - DonRotolo [more]
Unread 06-01-2013, 22:56
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Rookie Year: 2010
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
Press fitting
How much smaller than the diameter of a bearing would you make a hole in order to press fit it and have it be in firmly?
Thanks!
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 06-01-2013, 23:00
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Re: Press fitting
Here's a thread I started a while back that will help you. http://www.chiefdelphi.com/forums/sh...ight=Press+Fit
P.S. The search feature is very handy
Unread 06-01-2013, 23:07
UAH Class of 2019
Rookie Year: 2010
Re: Press fitting
That thread seems to be press fitting into sheet metal. What about directly into aluminum tube? And how many thousandths of an inch would you recommend? Also, to cut into the tube, can that be done? The you hinted at is more for sheet metal, which we do not have access to.
Unread 06-01-2013, 23:11
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Re: Press fitting
Sheet metal and the wall of your tubing has little difference when you are press fitting a bearing into it. you should be able to use the same sizes as that thread states.
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 06-01-2013, 23:13
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Rookie Year: 2011
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: Press fitting
Generally for FRC usage a thou under is enough.
The bigger issue is can you actually machine to that kind of tolerance?
A reamer would do it perfectly every time however just using say an endmill on a CNC machine you may be a few thou off due to tool wear causing a press fit to turn into a non fit.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
