Go to Post Our robot will use sensors to collect information about its environment, then discard that information and drive into a wall. - Jared Russell [more]
Unread 01-07-2013, 01:07 AM
IBeMad IBeMad is offline
FRC #3968
IBeMad is an unknown quantity at this point
NetworkTable crash in unmodified SimpleRobot template
I'm getting a null pointer exeption in
Code:
NetworkTable::Initialize()
on the following line:
Code:
staticProvider = new NetworkTableProvider(*(mode->CreateNode(ipAddress.c_str(), port, threadManager)));
This crash occurs in unmodified SimpleRobotTemplate code. How does something like this even get through QA, or is there even any QA to begin with? Sure seems like there isn't any...
Earlier on in the call stack, the crash stems from
Code:
SimpleRobot::StartCompetition()
when it calls
Code:
LiveWindow *lw = LiveWindow::GetInstance();
which creates a new instance of LiveWindow since it's the first time GetInstance() is called, which results in it calling
Code:
NetworkTable::GetTable("LiveWindow")
When will this be fixed in WPILib, and how can I work around it in the meantime?
