Go to Post The only way to make a noticeable shift in OUR culture is if there are a lot of small shifts. - JVN [more]
Unread 07-01-2013, 09:44
MatthewWalker MatthewWalker is offline
FRC #1448 (Parsons highschool Robotics)
MatthewWalker is an unknown quantity at this point
Clarification on Height restricitions
As per rule R03
total length of the FRAME PERIMETER sides may not exceed 112 in. (see Figure 4-1 for examples),
PLAYING CONFIGURATION horizontal dimensions may never exceed a 54 in. diameter vertical cylinder (see G23), and
height may never exceed 84 in. tall.
Emphasis mine.
Does the height restriction ever change? As in, During some parts of the match is your height lower than 84'' ?
Unread 07-01-2013, 09:48
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Rookie Year: 1999
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Re: Clarification on Height restricitions
Originally Posted by MatthewWalker View Post
As per rule R03
Emphasis mine.
R03
The ROBOT must satisfy the following size constraints:
G22
ROBOT height (as defined in relation to the ROBOT) must be restricted as follows during the MATCH:
If in contact with the carpet in its AUTO ZONE and/or its PYRAMID, ≤ 84 in.
Otherwise, ≤ 60 in.
Violation: FOUL. If continuous or repeated violations, TECHNICAL FOUL.
Wetzel
Viva Olancho!
Unread 07-01-2013, 09:55
Just did some more intense research and found a 60" height restriction
Unread 07-01-2013, 10:00
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Was wierd that this wasn't listed in the Robot Rules, you had to find it in the Game Rules. I'm sure this will be updated soon in the robot rules section.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 07-01-2013, 18:44
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Why? It is a game rule - it depends on what you are doing in the game. There is no hard and fast robot size rule, other than the 84" maximum at all times and the 54" cylinder.
(since 2004)
Unread 07-01-2013, 09:59
Mentor,QCR Planning
G22
A. If in contact with the carpet in its AUTO ZONE and/or its PYRAMID, ≤ 84 in.
B. Otherwise, ≤ 60 in.
Robot height is limited to 60 inches, unless you are in contact with carpet in your autozone or pyramid, then your height limit is 84 inches
