Go to Post I love some good datas, so tasty. - RoboChair [more]
Unread 07-01-2013, 14:01
Borntolose Borntolose is offline
AKA: Nadav Mailhot
FRC #1574 (Miscar)
Rookie Year: 2010
Borntolose is an unknown quantity at this point
Number of Frisbees Allowed in Autonomous Mode
Going over the rules of the game, we found it hard to understand if the limitation on controlling 4 frisbees is only in the Tele-Op period. Are we only allowed 4 frisbees in the Autonomous as well or can we control more?
Unread 07-01-2013, 14:04
JB's Avatar
JB JB is offline
FRC Kit of Parts Engineer
AKA: Jon Bryant
FRC #0238
JB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of light
Re: Number of Frisbees Allowed in Autonomous Mode
You are allowed to control 4 Frisbee's in auto but you can only start with 2 or 3 depending on where you are located. Below are the two rules that apply.
G06
TEAMS may preload White DISCS in or on the ROBOT before the MATCH.
If the ROBOT is in contact with any carpet outside its AUTO ZONE, the ROBOT may preload up to three (3) DISCS.
Otherwise, the ROBOT may preload up to two (2) DISCS.
G24
ROBOTS may not actively control more than four (4) DISCS at any one time.
So my prediction is that top tier teams will be putting in around 7 Frisbee's in auto.
My posts are solely my own and do not necessarily reflect the views or opinions of FIRSTŪ or my affiliated team.[/center]
FRCŪ Kit of Parts Engineer: 2014-Present
Team 238: 2016-Present
Team 1403: 2008-2014
Unread 07-01-2013, 14:13
AKA: Nadav Mailhot
FRC #1574 (Miscar)
Rookie Year: 2010
Are you certain that the "ROBOT Actions" rules also apply in the Autonomous Period or are the "AUTO Rules" the only rules relevant to the Autonomous Period?
I ask because one of my mentors says that he saw teams last year collecting more than three balls in the Autonomous before starting to shoot. According to him the limitation on three balls only applied during the Tele-Op and we were wondering if perhaps the limitation this year was also only for the Tele-Op.
Unread 07-01-2013, 14:28
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
The limitations on the quantity you can hold applies to both the autonomous and tele-operated portions of the match. Any teams that picked up more than 3 balls during hybrid last year should have received fouls for the infraction.
What is worth noting is that, in both games, game pieces scored in autonomous had the potential to be worth than 3 foul points. Last year a ball scored during hybrid was worth 4-6 points. This year a disc scored in autonomous is worth 2, 4, or 6 points depending on the goal it is scored in. Obviously it doesn't make sense to take fouls in order to score additional discs in the low goal, but it may be worth it to suffer the foul to score in the other two goals (if you're confident in your accuracy).
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
Rookie Year: 2013
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
You can only start with 2 or 3 depending on where you start, put you can pick up a fourth from the ground
Head Programmer / Driver
