Go to Post Being professional means doing things right. Being gracious means doing the right thing. They complement each other perfectly. But I think we should remember to use GP as a guide for our own behavior, not as a yardstick to measure others' shortcomings. - Alan Anderson [more]
Unread 08-01-2013, 09:33
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Re: Robot climbing times
Originally Posted by 45Auto View Post
That is correct, for a CIM pulling 133 amps.
What kind of 40 amp circuit breakers are you using?
Which number matters for your application depends on how long you will be drawing the maximum current during the lift. You can pull 133 amps for a couple seconds without issue.
Unread 08-01-2013, 13:10
Chris is me's Avatar
AKA: Pinecone
Just to be clear here, if you stall your CIMs when you're trying to climb, you're not moving anyway. You'll want to design your hanger so it runs at 30-some amps (or less) under load to get as close to the max power as you safely can. A little under is a good idea since your battery voltage will have dropped during the match.
You can generally safely run 1.5x-2x the breaker current for a few seconds without trouble. It's how most single speed drives begin pushing matches.
Unread 08-01-2013, 13:58
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
I'm really interested to see the value proposition that the elite teams take. Every year, there seems to be a killer design component that the elite figure out early, and the rest struggle to implement after seeing the effectiveness.
see: 2012 stingers, 2011 ramped minibot launchers/minimalist minibots, 2010 ball magnets/hanging on the vertical bars
I have a sneaking suspicion that there will be a divide amongst the elite this year. Some will have 30pt climbers that are effective, and others will have a corner based 20pt climb thats ridiculously fast (like some of the stupidly fast hangers in 2010 [~2s])
Unread 08-01-2013, 14:05
ptkunapuli478 ptkunapuli478 is offline
Team Role: CAD
ptkunapuli478 is an unknown quantity at this point
I would tend to agree, but I feel like there may be "elite teams" that actually choose not to concern themselves with climbing and instead focus on shooting in the end game to make up for the points. It's important to remember that when that signal comes at the last thirty seconds, the human players will be going berserk trying to throw frisbees onto the field to make shooting easier for their alliance. So the shooting opportunity is very real in the last thirty seconds
Team 341 Miss Daisy
Pranav Kunapuli
Captain
CAD
Unread 08-01-2013, 14:09
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
Right-o. If you can shoot seven three pointers and make a ten-point hang on the lowest bar in the same amount of time, you just one-upped a "thirty point climb". Ten three pointers and no hang and you tied it.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
Unread 08-01-2013, 14:27
I expect as always that the average team will struggle to score 7 3pters in the entire match.
The elite will be able to, but the best will 30pt hang in under 15 seconds also.
Unread 08-01-2013, 15:27
jeremy callahan's Avatar
jeremy callahan jeremy callahan is offline
Mentor
FRC #5053
Rookie Year: 2011
jeremy callahan will become famous soon enough
so do you think the hightest score will be like 98? im thinking 30pt hang, 7 discs 35pts, auton 18 for the "Elite Teams" extra 15 points?
Unread 08-01-2013, 14:13
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
...but I feel like there may be "elite teams" that actually choose not to concern themselves with climbing and instead focus on shooting in the end game to make up for the points. It's important to remember that when that signal comes at the last thirty seconds, the human players will be going berserk trying to throw frisbees onto the field to make shooting easier for their alliance. So the shooting opportunity is very real in the last thirty seconds
Unless their team's number is 1717*, I don't think even the elite teams can consistently score 30 disc points in 10-20 seconds by themselves. 20-21 disc pts + a 10-pt climb may be more feasible, but 30 disc points is tough.
Plus, elite alliances won't have any discs left to huck at the end. (edit-- this doesn't account for the possibility of a higher-accuracy score of 4 colored discs into the pyramid goal either).
So I definitely think that high-caliber teams want a 30-point climb as an option for endgame.
*Of course, the kids who built an 18-shot bot last year aren't on that team any more
GitHub
Unread 08-01-2013, 07:02
JesseK's Avatar
FRC #1885 (ILITE)
We have a conceptual design that will be easy to automate. We're in the process of proofing it now. Taking away driver hesitation between tiny repeatable movements should easily shave off 5 seconds, no matter what the final motors/gears are.
GitHub
Unread 08-01-2013, 12:06
AlexH AlexH is offline
Rookie Year: 2010
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
Originally Posted by nuggetsyl View Post
Ok whats you guess on how long it will take to climb to the top of the tower?
it will be like the minibots
some will be sub 5s and others will be much much slower.
My Instructables
Unread 08-01-2013, 12:10
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Like said previously, I'm calling out sub 5s climbs as impossible.
Originally Posted by Paul Copioli
Nessy 2013 is the 4 second legal climb
I'm going out on a limb and saying that it's not going to happen. Feel free to prove me wrong, I really do.
EDIT: Team 217 has not deemed it impossible. It is simply highly unlikely.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 08-01-2013, 12:46
Paul Copioli's Avatar Unsung FIRST Hero Woodie Flowers Award
Paul Copioli Paul Copioli is offline
President, VEX Robotics, Inc.
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2000
Paul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond repute
If even Team 217 deems it as impossible, I'm going out on a limb and saying that it's not going to happen. Feel free to prove me wrong, I really do.
For clarification, Team 217 does not deem it impossible, I personally think it is like Nessy, some people will claim it, but none will prove it.
But I said the same thing last year about the triple balance ...
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 08-01-2013, 12:56
pfreivald's Avatar
I've learned not to underestimate FRC teams...
I have a design that could make a rather smooth ~4-second climb, but we've deemed it beyond our ability to manufacture to desired specifications.
That said, I think well more teams will have ideas that could do it than teams that will have mechanisms that will.
Team 1551
I write books, too!
Unread 08-01-2013, 14:04
JesseK's Avatar
FRC #1885 (ILITE)
I think we may see a sub 4-second climb by 1 or 2 teams once or twice. I don't think those teams will be able to do it consistently without major repair work.
GitHub
