Go to Post How do you earn yourself 500 PM's, 200 e-mails, 100 replies to a post, and an instant 5 to 6 bars in rep? If your name is Grant Imahara, make yourself known to the Chief Delphi community. - Andy Grady [more]
Thread Tools Rating: Thread Rating: 3 votes, 3.67 average. Display Modes
Unread 16-01-2016, 13:47
RugnarStormBorn RugnarStormBorn is offline
User of the Matrix
AKA: Michael Brooks
FRC #2130 (Alpha+)
Rookie Year: 2013
RugnarStormBorn is an unknown quantity at this point
Re: Robot Builder?
So...thread necromanceries here but when I try executing RobotBuilder from the command prompt we get "Error: Unable to access jarfile RobotBuilder.jar"
Unread 16-01-2016, 13:52
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Robot Builder?
Are you in the same directory as RobotBuilder.jar?
Unread 16-01-2016, 14:09
User of the Matrix
AKA: Michael Brooks
FRC #2130 (Alpha+)
Rookie Year: 2013
Re: Robot Builder?
Whelp, that would've undoubtedly helped...guess I shouldn't do this stuff when I'm half asleep. XD
But still...nothing opening, do you want me to post what the cmd prompt came up with?
Rookie Year: 1997
Re: Robot Builder?
Yes
Unread 16-01-2016, 14:15
User of the Matrix
AKA: Michael Brooks
FRC #2130 (Alpha+)
Rookie Year: 2013
Re: Robot Builder?
C:\Users\jones\wpilib\tools>java -jar RobotBuilder.jar
Extension components: []
Adding extensions for section: Hidden
Adding extensions for section: Subsystems
Adding extensions for section: Controllers
Adding extensions for section: Sensors
Adding extensions for section: Actuators
Adding extensions for section: Pneumatics
Adding extensions for section: OI
Adding extensions for section: Commands
Exception in thread "AWT-EventQueue-0" while scanning for the next token
found character '\t' that cannot start any token
in "<reader>", line 3, column 1:
<static-widget class="edu.wpi.f ...
at org.yaml.snakeyaml.scanner.ScannerImpl.fetchMoreTo kens(ScannerImpl.ja
va:413)
at org.yaml.snakeyaml.scanner.ScannerImpl.peekToken(S cannerImpl.java:247
at org.yaml.snakeyaml.parser.ParserImpl$ParseDocument End.produce(ParserI
mpl.java:264)
at org.yaml.snakeyaml.parser.ParserImpl.peekEvent(Par serImpl.java:160)
at org.yaml.snakeyaml.parser.ParserImpl.getEvent(Pars erImpl.java:170)
at org.yaml.snakeyaml.composer.Composer.composeDocume nt(Composer.java:12
4)
at org.yaml.snakeyaml.composer.Composer.getNode(Compo ser.java:84)
at org.yaml.snakeyaml.constructor.BaseConstructor.get Data(BaseConstructo
r.java:104)
at org.yaml.snakeyaml.Yaml$1.next(Yaml.java:501)
at robotbuilder.robottree.RobotTree.load(RobotTree.ja va:387)
at robotbuilder.robottree.RobotTree.load(RobotTree.ja va:361)
at robotbuilder.MainFrame.openDefaultFile(MainFrame.j ava:141)
at robotbuilder.RobotBuilder.lambda$main$85(RobotBuil der.java:44)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessI mpl.doIntersectionP
rivilege(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilter s(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(U nknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarch y(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Unread 17-01-2016, 16:32
krieck's Avatar
krieck krieck is offline
AKA: Keith
FRC #2846 (Firebears)
Rookie Year: 2012
krieck is an unknown quantity at this point
Re: Robot Builder?
I have a theory on what's going wrong for you. When RobotBuilder starts up, it tries to load the robot configuration file it was working on previously. The name of the file it was most recently working on is stashed using Java's Preferences utility. I think that on your system it is mixed up, and is reading a file that is isn't a valid RobotBuilder YAML file.
If we clean out RobotBuilder's preferences, then it should revert to opening up a blank robot configuration.
Unfortunately, I don't know that there is anything in the RobotBuilder code to self-correct on this subject. Java preferences are stored in different locations for each different operating system. Macs keep them in PLIST files in the user Library. I think Windows stashes them in the registry. Linux has its own set of files.
The simplest solution I can think of is to run a short Java program that cleans out the RobotBuilder preferences. Try compiling and executing the following. It won't do any harm to your system:
Code:
import java.util.prefs.Preferences;
public class PreferencesCleaner {
	public static void main(String[] args) throws Exception {
		Preferences prefs = Preferences.userRoot().node("robotbuilder.MainFrame");
		prefs.clear();
Unread 19-01-2016, 13:25
BradAMiller BradAMiller is offline
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant future
Re: Robot Builder?
The old or corrupted preferences or previous save file seems like it might be your problem. Have you gotten past the issue you were having?
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
Unread 20-01-2016, 20:04
User of the Matrix
AKA: Michael Brooks
FRC #2130 (Alpha+)
Rookie Year: 2013
Re: Robot Builder?
Code:
		prefs.clear();
This fixed it! Thanks a million!
Unread 02-05-2016, 09:10
Coach Seb's Avatar
Coach Seb Coach Seb is online now
AKA: Sebastien Cournoyer
FRC #5860 (Full Metal Muskrats)
Team Role: Coach
Rookie Year: 2015
Coach Seb is an unknown quantity at this point
Re: Robot Builder?
Wow.... just watched the Robo Builder overview videos from Brad Miller and i am excited...
Can this be use for both FTC and FRC?
We are a rookie team, we depended on one programmer last season and he did good with labview with no experience, unfortunately he is leaving for college and we are starting our programming team from scratch.
Many teams recommended going to JAVA as it would be a much easier programming language to ;earn for beginners and there is tons of ways for the students to learn it... I am still not totally sold as Labview seem to have some great material online too...
And then i found this thread... I really like what i seen in the video... just trying to wrap my head around where to start and how much of a learning curve is it going to be...
Our programmers will most likely work on both the FTC and FRC robot next season and beyond !
Any input would be appreciated...
