Go to Post What, there is life outside of CD? - JB987 [more]
Unread 08-01-2013, 23:43
cdizzle cdizzle is offline
FRC #2367
cdizzle is an unknown quantity at this point
Gear Ratio to Maximize Chassis Speed?
Hi Everybody,
So, we want to maximize our chassis speed but still be able to carry at least 120 pounds, does anybody know the gear ratio we'd need to use?
Our prototype chassis is basically the kitbot, it has a 6 wheel drive, and is driven by 2 CIMs with 2 toughbox minis, but replacing gearboxes is an option.
Adding motors is also an option, but we would like to stray away from that.
Thank you for your help!
-Team 2367
Unread 08-01-2013, 23:45
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Gear Ratio to Maximize Chassis Speed?
Originally Posted by cdizzle View Post
Hi Everybody,
-Team 2367
http://www.chiefdelphi.com/media/papers/2755
http://www.chiefdelphi.com/media/papers/2059
http://www.chiefdelphi.com/media/papers/1469
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Rookie Year: 2012
Gregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond repute
The kitbot has a wonderful ratio for the needs you described. Add 2 more CIMS to your gearboxes though.
What are nationals? Sounds like a fun American party, can we Canadians come?
“For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.” -Jean Dubuffet
"Insanity is doing the same thing over and over again and expecting different results." -Albert Einstein
FLL 2011-2015 Glen Ames Robotics-Student, Mentor
FRC 2012-2013 Team 907-Scouting Lead, Strategy Lead, Human Player, Driver
FRC 2014-2015 Team 1310-Mechanical, Electrical, Drive Captain
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 08-01-2013, 23:46
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Need to know wheels and total weight of current bot.
Also, your current setup will do okay. Add two more CIMS and you'll do as good as a lot of other teams. If you don't, your acceleration will be kinda bad (it might take half the field to get up to speed). Think of motors as torque generators (with max RPM limits).
Also, search around on the forum first. There exists at least one other thread that discussed this very topic (with some more generalities), and you're not the only team with this question, nor are you the only one that needs answers. See http://www.chiefdelphi.com/forums/search.php.
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 09-01-2013, 00:56
FRC #2367
Thanks for the input! We're planning to have 1 or 2 DC motors on other places on our robot, but one concern of ours is the battery draining really quickly if we put 5 or 6 DC motors on there. Do you think we should worry about that?
Unread 09-01-2013, 04:41
AKA: Nathan Hui
Probably not. We've run a 4 CIM drivetrain for several years now, and those robots have had multiple other motors on there. Just bewarned that driving and doing other stuff at the same time might cause brownouts. If you use only new batteries for competition, and keep them topped off, you should be okay, but run the calcs for brownout scenarios just to be safe.
Nathan Hui
FTC 4950, 6038
Unread 09-01-2013, 12:16
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
Rookie Year: 2012
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Have teams noticed much difference between 2 CIM and 4 CIM drivetrains, outside of pushing power? We might cut it down to 2 to save weight if it doesn't substantially affect speed and maneuverability.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 09-01-2013, 12:24
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is online now
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
I would not recommend this, you will notice a significant decrease in acceleration, and your robot will feel sluggish. In addition, you would have to change your gearing or you would likely not be "traction limited". That is to say, when your robot hits a wall or gets in a pushing match, your wheels will not spin.
You might think this is a good thing, but it means that your motors are stalled and drawing maximum current, which will very quickly blow your drivetrain breakers (and could possibly blow your 120A main breaker).
Unread 09-01-2013, 12:37
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
This, all of this.
There's another thing to think about as well. If you're removing CIMs from your drive train, odds are they're down low in the robot. Do you really want to remove ~5lbs from some area that is less than 12" off the floor? My experience tells me that this is a horrible idea, even if we're only looking at Center of Gravity and ignoring everything Evan said above.
There is a reason that the '4 CIM' drive train has become the standard in FRC. When properly geared, you shouldn't see any issue with brownouts or lessened battery life...
If you're looking for a good resource for doing the calculations that go into designing just about any FRC mechanism, check out this white paper: http://www.chiefdelphi.com/media/papers/2755
