Go to Post Speaking about healthier, the Texas air was sooooooooo much cleaner than NJ air, I felt my life expectancy being extended another 5 years. - The Chinese Guy [more]
Unread 09-01-2013, 14:47
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
Team Role: Coach
Rookie Year: 2007
Siri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond repute
Send a message via ICQ to Siri
Re: 54 in cylinder
Originally Posted by Jon Stratis View Post
The two rules were written quite differently:
2012:
2013:
In 2012, they defined the constraint with respect to the robot - 14 inches past the frame perimeter. This year, it's defined with respect to horizontal and vertical, which I take, by their very definitions, to be constant with respect to a level floor, which is another way of saying constant with respect to the local gravity field - for all practical purposes, they don't change as the robot orientation changes, for all games played here on Earth. If you play a game out in the middle of space, you might have a different answer .
I do not believe that anyone referencing 2012 is referring to G21 (certainly I'm not). The questions last year were almost all about the allowable height and width with respect to the floor while you were on the bridge or barrier. Numerous Q&A questions on these subjects even led to updating the manual wording itself. This year's situation, where again the robot is expected to climb an inclined object/traverse a barrier, are quite similar in that respect.
Unread 09-01-2013, 00:35
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
Re: 54 in cylinder
The way I have read this, is that the 54 inch cylinder applies to the area parallel to the bumpers while on the ground. Hence the penalties for tipping.
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 14-01-2013, 06:52
Ty Tremblay's Avatar
Ty Tremblay Ty Tremblay is offline
Robotics Engineer
FRC #0319 (Big Bad Bob)
Ty Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond repute
Re: 54 in cylinder
In a related note. Does the 54 inch rule include the robot's bumpers?
Edit: Per Team Update #1, the bumpers are included.
