Go to Post Think of the build season as kiddie bowling. Mentors should be the bumpers and your mom who lines you up and gives you advice. - Joe Matt [more]
Unread 09-01-2013, 02:29
Kusha's Avatar
Kusha Kusha is offline
Crimpin' ain't easy
AKA: Kusha Gharahi
no team (Looking for a team)
Rookie Year: 2010
Kusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the rough
Shooting full court?
With all these prototype videos I've seen, there are some impressive ranges going on. Will teams start to "camp" the loading zone and just shoot full court? Is this even a plausible idea?
“Be the change that you wish to see in the world.”
― Mahatma Gandhi
Unread 09-01-2013, 02:32
Austin2046's Avatar
Austin2046 Austin2046 is offline
Design, Strategy & Scouting Mentor
FRC #2046 (Bear Metal)
Rookie Year: 2007
Austin2046 has a spectacular aura aboutAustin2046 has a spectacular aura about
Re: Shooting full court?
i definately think it's plausable... but i do worry about tall opposing robots just parking in front of you and blocking shots... not to mention pyramids could be in the way.
Unread 09-01-2013, 03:14
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
Basic calculations show that an 84" robot could block fairly effectively even from several feet away from the feeding zone, even if you are shooting from the maximum height of 60". However, it is difficult to speculate how many robots will actually deploy to 84" while playing defense.
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
Unread 09-01-2013, 03:16
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
People thought of doing that last year with the basketballs and outside of midcourt shots I can't recall any teams firing from the other side of the field. Better to move in for a closer more accurate shot than waste it blindly shooting from a greater distance.
Unread 09-01-2013, 03:22
DampRobot's Avatar
DampRobot DampRobot is offline
Physics Major
AKA: Roger Romani
FRC #0100 (The Wildhats) and FRC#971 (Spartan Robotics)
Rookie Year: 2010
DampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond repute
People think this every year, and every year they fail to show up. I have yet to see any full court shooters that I would call successful. Remember, even the 971's and 548's of FRC have had huge successes with machines that require shots from under (or usually under) the goals. It's often beter to get up close and personal with the goals in return for a higher percentage.
I will give you a cookie if you can show me an actual FRC team that fields a full court shooter with a percentage higher than 30%.
The mind is not a vessel to be filled, but a fire to be lighted.
-Plutarch
Unread 09-01-2013, 03:32
dcarr's Avatar
#HoldStrong
AKA: David Carr
Frisbees are a different animal than any previous gamepiece - but full-court is still full-court.
If anyone makes a robot that parks in the feeder station and fires off 45 rounds at high accuracy while overcoming the tough angle, pyramids, and potential defense, it will be a sight to behold.
Team 3309
Team3309.org
Unread 09-01-2013, 07:04
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
I am sure that at least one team will try this and have reasonable success.....until the frisbeeswarp. We all know that this will happen, but no one seems to consider it as a factor.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 09-01-2013, 08:13
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
Rookie Year: 2011
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
After some time playing with the simulator, I've concluded that the ideal alliance this year is a dedicated climber and two shooters, one of which can feed directly from the station and the other with great floor pickup.
For the first part of the match, the station feeder just shoots disks downfield. If some of those happen to score, great, but more important is reducing the number of trips to the feeder station to retrieve disks. Last year, good inbounders were able to keep their robots supplied with basketballs, but this year a robot will have to provide that function, at least until the inbounders can throw disks to their robots.
From the simulator, we learned that the real bottleneck to scoring is disk supply. Good scoring robots quickly exhaust the available disks on the floor. Driving to the drivers station to get more is a real time killer, especially if slowed down by any halfhearted attempts at defense.
Think about the problem this way: After teleop, a single robot has 6 disks easily reachable on the floor available for scoring. If limited to getting disks from the feeder station, and generously assuming 5 trips to refill, that is 20 disks more. Any defense that slows down round trips from the feeder station could easily reduce the number of trips to 2 or 3.
For every disk available for scoring, you pay a price for that disk measured in seconds to retrieve it. The highest price you can pay is driving back and forth to get them, and the other alliance can drive the price higher by playing defense. The lowest price you can pay is parking at the feeder station and shooting them downfield. There is an optimum number of disks the inbounding robot would want to shoot downfield. Too many and they will lay on the field un-scored at the end of the match. Too few and the scoring robot(s) will run out and have to go hunting for more.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 09-01-2013, 08:21
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Donut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond repute
Was the limited supply of disks (45 per alliance station) ever a factor? I know the simulator may be an overestimate for a typical team's ability but I'm curious if the disk supply matters even for an elite level group.
FRC Team 498 (Peoria, AZ), Student: 2004 - 2007
FRC Team 498 (Peoria, AZ), Mentor: 2008 - 2011
FRC Team 167 (Iowa City, IA), Mentor: 2012 - 2014
FRC Team 2662 (Tolleson, AZ), Mentor: 2014 - Present
Unread 09-01-2013, 08:49
Taylor's Avatar
Taylor Taylor is online now
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Team Role: Teacher
I'll just leave this here.
Hi!
Unread 09-01-2013, 09:14
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
Rookie Year: 2010
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
This year the game piece supply is comparatively larger. Each alliance is given 51 probably unshared discs (assuming discs are not stolen off the ground) Last year there was 18 shared balls for both aliances. At least until MSC I will find it hard to believe on average each robot on an alliance can score 17 discs and deplete the supply.
Unread 09-01-2013, 09:48
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
You will only be at 60" when down field. 84" in your autozone. Compare those heights to the bottoms of the two far-wall holes.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 09-01-2013, 10:15
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
My Autozone is your feeder zone... I will be 84" in my autozone... just to protect you from making shots from there. You will probably still feed your zone by missing me, but you are not scoring from the feed zone. If you try to score from there, the Frisbee at best in my autozone, and worst ends up in my low score bin. . . think about it.
The sooner we get behind schedule, the more time we have to catch up.
Unread 09-01-2013, 10:37
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
Rookie Year: 2012
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
There is danger in attempting to block the feeder slots, if you get too close, the robot at the feeder can rack up penalties against you.
A good allied defender bot can also mitigate blocking if it's key to the teams strategy. It's not difficult to park in front of your ally against the wall.
I would not be surprised if we see some teams making full court shots with some degree of success. Even 50% accuracy is deadly if you've got an allied bot that can pickup the other half.
  #15   Spotlight this post!
Unread 09-01-2013, 10:43
Ido_Wolf's Avatar
Ido_Wolf Ido_Wolf is offline
LabVIEW Addict
AKA: Ido
FRC #2230 (General Angels)
Rookie Year: 2011
Ido_Wolf is an unknown quantity at this point
Seems a lot more doable for mediocre teams than last year, and I kinda have a reckless prediction that many teams out there would give up on trying to make an extraordinarily good climbing mechanism, at least in my regional...so a great shooter would be the next great thing to put some effort into for those teams.
