Go to Post I am a human wiring diagram, how can i help you? - Jeffy [more]
Unread 09-01-2013, 16:52
zekesaucedo's Avatar
zekesaucedo zekesaucedo is offline
FRC #3345 (Metal Jackets)
Team Role: Leadership
Rookie Year: 2011
zekesaucedo is an unknown quantity at this point
cRIO-FRC Power Connector help
Having a bit of trouble getting power to the cRIO, wondering if someone could shed some light on which connectors to put the wires into. Thanks, guys!
~President of FRC Team 3345 Metal Jackets
Unread 09-01-2013, 16:59
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
Rookie Year: 1997
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Re: cRIO-FRC Power Connector help
V for Voltage (aka red or positive terminal), C for Common (aka black or negative terminal).
My team uses the outer terminals on the connector so there's no confusion about what is in which slot. Just make sure your connections are equally correct on the PDB side of that cable.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 09-01-2013, 17:02
omgnocomms's Avatar
omgnocomms omgnocomms is offline
omgnocomms will become famous soon enoughomgnocomms will become famous soon enough
Based on the "Wiring the 2013 FRC Control System" guide1 found linked from the "Getting Started With the 2013 Control System" guide2 linked from "2013 Technical Resources"3 linked from the FRC Game Manual4,
You can use the following picture to wire your cRio appropriately:
http://wpilib.screenstepslive.com/s/...age_id=1787517
Unread 09-01-2013, 17:34
Rookie Year: 2011
Our cRIO is now functional! Thanks a bunch, guys; we really appreciate your help!
