Go to Post I don't really have a problem with school, as long as it doesn't get in the way of learning. - lukevanoort [more]
Unread 09-01-2013, 19:26
Ganondalf Ganondalf is offline
FRC #4665
Ganondalf is an unknown quantity at this point
Programming a Victor motor (Logitech Joysticks)
Hello, I have a victor motor and what I want to do is have the trigger on my right joystick spin the motor one direction and the trigger on my left the other. I'm using two joysticks (tank drive). How would I do this using LabVIEW. Thanks in advance!
Allons-y!
Unread 09-01-2013, 19:37
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Programming a Victor motor (Logitech Joysticks)
This doesn't have everything wired, but it might give you the idea.
You have to open the motor in Begin.vi, name it, and use both the motor and joystick names in Teleop.vi.
Unread 09-01-2013, 19:38
FRC #4665
That'll do it! Thanks!
Unread 09-01-2013, 19:42
Make sure that in Begin.vi, you open a reference to both joysticks and store them by name. By default there is only one being opened. Also make sure to open the motor controller and store it with a name.
In TeleOp, retrieve the refnums using the names and run code similar to below.
The code uses the select node to choose a value depending on the state of the button, and when it is time to combine the button values, I simply added them, deciding that if both are pressed, don't spin the motor at all. I decided to spin the motors at half speed, so I use 0.5 and -0.5.
Greg McKaskle
Unread 09-01-2013, 19:47
FRC #4665
Thank you so much!
