Go to Post Use these tools as a starting point, not as an end product. - Tom Bottiglieri [more]
Unread 09-01-2013, 23:18
Hellsome Hellsome is offline
FRC #2443
Hellsome is an unknown quantity at this point
Programming Simulator
Does the programming simulator mentioned at kickoff this year only work with Labview?
Unread 10-01-2013, 08:13
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
Rookie Year: 2012
gixxy is on a distinguished road
Re: Programming Simulator
Unfortunately yes.
Programmer - A creature known for converting Caffeine into Code.
Studying Computer Science @ Louisiana Tech University
Associate Consultant @ Fenway Group
2012-13: 3946 - Head of Programming, Electrical and Web
2014 - 3468 - Programming Mentor
2015 - Present - Lurker
Unread 10-01-2013, 23:13
TheGuyz TheGuyz is offline
FRC #2443
TheGuyz is an unknown quantity at this point
So is there no way we can use it with our java program? Like we aren't able to load it on there and see how it works?
Unread 11-01-2013, 07:35
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The robot simulator is presently LabVIEW-only. The LabVIEW versions of many of the WPI library functions are written to be able to communicate with the simulator instead of the cRIO's FPGA when running on the PC. I believe the simulator display is also a LabVIEW window, though I'm not totally sure of that.
Unread 11-01-2013, 07:48
The simulator is a portion of the LabVIEW for Robotics Module typically sold into universities. The solver is based on ODE, Open Dynamics Engine, and the window is based on OSG, Open Scene Graph. The OSG is embedded in a LV indicator called the 3D Picture Control, and that is placed on a LV panel to complete the simulation window.
So, at this point, it is available within LV, but the Java and C++ integration wasn't completed. We hope to see it completed next year.
Greg McKaskle
