Go to Post There is nothing that compares to the smell of burning flesh, especially when it is your own. - Al Skierkiewicz [more]
Unread 09-01-2013, 23:32
TheGuyz TheGuyz is offline
FRC #2443
TheGuyz is an unknown quantity at this point
Pyramid rule clarification
Do the levels of the pyramid extend outside of the pyramid frame? With the exception of level 0
Unread 09-01-2013, 23:38
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Re: Pyramid rule clarification
Yes. It is implied that the levels of the pyramid extend to the full extent of the field, and no rules as of yet have nullified that interpretation.
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 10-01-2013, 00:08
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is offline
Coach
FRC #1086 (Blue Cheese)
Team Role: Teacher
Rookie Year: 2007
wilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond repute
If this is true, then a robot this is over 30" tall could not legally climb the Pyramid. IS this the intent of the rule?
Currently: Coach FRC 1086/FTC 93
2006-2011 Coach FRC 2106/FTC 35
If you come to a FRC event to see a robot competition, you are missing the point.
Unread 10-01-2013, 00:11
Domtech's Avatar
Domtech Domtech is offline
I Do Everything
AKA: Dominic
FRC #2412 (Robototes)
Domtech is an unknown quantity at this point
Over 30 inches is fine, as long as you don't CONTACT it in more than 2 zones.
Unread 10-01-2013, 00:12
wilsonmw04's Avatar
Coach
Team Role: Teacher
Rookie Year: 2007
Is was just going to post this:
The requirements in Section 3.1.5.2 A and B pertain to the ROBOT'S contact with the PYRAMID and/or floor within each Level, not the ROBOT'S presence in the physical space of the Level.
this makes life MUCH easier
Unread 10-01-2013, 00:18
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
Alright I thinking know what you mean but would you care to clarify?
"Sometimes the questions are
complicated but the answers are simple."
- Dr. Seuss
Unread 10-01-2013, 00:27
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
I think this might help. So your grabbing the level 1 bar, still touching the floor, but your robot is more than 30 inches high so it extends into the airspace of level 2. But since your are not in contact with level 2 bar, you are only consider in two levels. The airspace between the bars does not count to the "what levels your in".
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 10-01-2013, 00:38
nitneylion452's Avatar
nitneylion452 nitneylion452 is offline
AKA: Joe Lee
FRC #3167 (Environmental Tectonics Crusaders)
Rookie Year: 2010
nitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud of
Well, not quite. Being in a level's airspace is ok. It's touching the pyramid in more than 2 zones that isn't. For example, touching the floor (level 0), the bar in level 1, and the bar in level 2. Simply touching the floor and the bar in level 1 is ok, even if your robot is occupying some of level 2's airspace. The robot just can't touch the pyramid in more than 2 zones at once.
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 10-01-2013, 00:39
AKA: Garty
Yes it does! Thank you!
- Dr. Seuss
Unread 10-01-2013, 07:07
wilsonmw04's Avatar
Coach
Team Role: Teacher
Rookie Year: 2007
this is what I was concerned about. The clarification takes it off the table.
Unread 10-01-2013, 12:05
joshjet joshjet is offline
FRC #4344
joshjet is an unknown quantity at this point
I'm sorry, but I guess I still don't understand completely. Does this mean that we would be unable to reach directly to the second bar while sitting on the ground?
Unread 10-01-2013, 12:08
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
Team Role: Coach
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Yes...
"A genius is just a talented person who does his homework" T. Edison
Unread 10-01-2013, 13:17
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
If you're sitting on the ground, you are in contact with Level 0. If you then touch the second bar, you are in contact with the pyramid in Level 2. Contact in levels 0 and 2 simultaneously invalidates a CLIMB attempt.
Unread 10-01-2013, 13:48
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
Rookie Year: 2012
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
The Q&A has cleared up a few points of confusion regarding climbing (one pointed out earlier):
The decision of whether or not a climb is valid/invalid is made based on where the robot makes contact with the pyramid only, not air space *1. Sequential contact means in order, but also not skipping levels *2.
*1
Q.Figure 3-4 on page 28/90 shows Level 2 just above the horizontal bar. Since the rule states no
more than two zones why is it (or is it) permissible to hook the pipe while still on the floor and if so
how far into level 2 can you go? Does that include the side pipes?
A.The requirements in Section 3.1.5.2 A and B pertain to the ROBOT'S contact with the PYRAMID
*2
Q.Can the robot go from the floor to level 2 while climbing the pyramid or does it have to climb to
level 1 first and then level 2? I need clarification
A.Per Section 3.1.5.2, a ROBOT has CLIMBED its PYRAMID if it contacts the PYRAMID and/or the floor (Level 0) in sequential order (Level 0, 1, 2, 3) during ascent. Skipping a level (i.e. going from
the floor directly to Level 2) would not meet the "sequential order" requirement.
The scoring of your robot however, is determined by the lowest air space (zone) is occupies *3, including the bumpers *4.
*3
Q.Is the climb score counted by lowest point relative to a horizontal plane at the top of each rung,
or by the lowest point of the robot physically touching the tower. I.E. If an robot is hanging down
into zone 2, but is touching only the steel in zone 3, is his score 20 or 30?
A.Per Section 3.1.5.2, the Level to which a ROBOT has CLIMBED is determined by the lowest point
of the ROBOT (not the lowest point of the ROBOT contacting the PYRAMID).
*4
Q.When hanging does the lowest point of the robot include the bumpers?
A.Yes.
Also, while not directly related to the pyramid, Q&A has also stated that the 54" cylinder limit for appendages is always with respect to the ground, so while climbing at a 68deg angle, an appendage that would extend outside the 54" cylinder when flat on the ground may be used *5. Conversely, the height requirement of 60"/84" is always taken with respect to the base of the robot *6.
*5
Q.Is the 54 inch envelope diameter (figure 3-5) orientation sensitive ie is its axis always vertical
regardless of the robots axis ie such as when the robot climbs?
A.The vertical cylinder specified in G23 is not coupled with the ROBOT's orientation and is always
vertical.
*6
Q.Rule G22 places height restrictions "in relation to the ROBOT." Does this apply to G23 (horizontal
restrictions)? When climbing the pyramid, extending an appendage "out" from the robot but "up" in
space might extend past the cylinder if it is taken relative to the robot, as opposed to the ground.
A.The height requirement in G22 is relative to the ROBOT. The horizontal volume requirement of
G23 is relative to the FIELD (see answer to [Q15]).
A lot of the conclusions I've stated are reinforced by multiple answers to similar questions, I tried to pick the most clear instance, but please check the Q&A if I didn't justify all of my conclusions completely, and if I'm wrong, do correct me
  #15   Spotlight this post!
Unread 09-01-2013, 23:45
FRC #2443
Okay thanks. We were also wondering when does the next level start above each bar?
