Go to Post While searching is not as glamorous, I'm certain you could find a lot of good resources related to this topic. - Katie_UPS [more]
Unread 10-01-2013, 12:36
ctccromer's Avatar
ctccromer ctccromer is offline
Animus
AKA: Tucker Campbell
FRC #3753 (Bulah Bots)
Rookie Year: 2012
ctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to all
First time with an Axis Camera, need help getting started
This is 3753's third year as a team. Our first year the previous programmer wired the camera to our robot but didn't use it as anything more than a decoration
So yesterday I tried to hook up our Axis camera to begin setting up our team's first camera/aiming system, however without any lights on the camera, I have no idea if I have power to it or not.
I also don't know how to check if the ethernet connection works fine.
Team 3753 BulahBots
Unread 10-01-2013, 12:39
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: First time with an Axis Camera, need help getting started
There is a lighted ring around the lense of the camera-yellow while booting, green when operating.
You can test the Ethernet connect by browsing to the camer.
Have you setup the camera using the FRC camera utility?
Unread 10-01-2013, 16:34
ctccromer's Avatar
Animus
Rookie Year: 2012
Thats what I read but I didn't see anything. Perhaps it's because its the camera included back in 2011's season (the M1011) or maybe I'm just blind
Team 3753 BulahBots
Unread 10-01-2013, 18:00
Just Itinerant
Here are some pictures I found.
Including one of the back where there are green power lights.
The back lights come on a couple of seconds after it gets power.
The yellow light won't appear for 15 seconds.
The green light appears after 45 seconds.
Give or take.
ID:	13449  Click image for larger version
ID:	13450  Click image for larger version
Unread 10-01-2013, 21:06
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
How are you trying to power to the camera? Where are the wires to it coming from? If you aren't getting any lights, it might be faulty. Was it ever connected to anything besides the dedicated 5 volt output on the Power Distribution Board?
Unread 10-01-2013, 21:49
ctccromer's Avatar
Animus
Rookie Year: 2012
thanks for the pictures! I was looking at the camera and didn't see any lights on the front and became thoroughly confused.. Couldn't find any pictures like that when I googled it
As for the power source, when they tried to use it back in 2011, they severed the power cord from the wall plug so that it could be plugged into the 5volt slot on the PDP. However a couple of our wires have been a little iffy, and since I didn't know where the lights came on, I've been confused if we actually had power to the camera or not.
Now that I have those pictures I can hopefully test it tomorrow and see for sure
Thanks for the help! Will post again if I have more issues setting it up
Team 3753 BulahBots
Unread 11-01-2013, 00:00
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
Rookie Year: 2012
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
There should also be a small power LED on the backside of the camera, FYI
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 11-01-2013, 01:43
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
Rookie Year: 2011
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Both are vastly different in practice.
If you only want to use the camera for viewing on the driver station, all that is needed is to power the camera and connect it to the robots radio. Before you will see a picture on the driver station though, the camera's ip and account info must be updated to match that on the driver station. This is done though a setup utility detailed in the section on setting up a camera here
If you want to actually process the images, you will most likely want to look into the Vision assistant provided with all of your driver station stuff. If you capture a photo from the camera (By opening 10.37.53.11 in a web browser on your driver station while the camera is operating on your robot), you can load the image into the vision assistant and try out different operations on the image. For example, if you are illuminating the target with green LEDs, you may want to filter out anything that isnt your green color to get the targets in your image and then detect blobs on the screen, effective finding where the goals are in relation to your robot (To be effective, you'll have to do more, that was just an example).
We use Java, and for every function you do on the image, there is an equivilant "wrapper" in java for.
If you use labview, I think you can even just export the processing code directly for use on your crio.
Hope this helped and feel free to ask more questions. Also, search the white papers. There's alot of good stuff in there.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 11-01-2013, 03:14
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Make sure the polarity of the power is correct. If it isn't, you could cause damage to the camera. DO NOT PLUG THE CAMERA IN TO CHECK. Use a voltmeter to check that the plug has the proper polarity.
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 11-01-2013, 11:38
ctccromer's Avatar
Animus
Rookie Year: 2012
My teacher and I just tested everything with a voltmeter and the PDP is indeed giving 5.05V (from 5.0 to 5.1, so its good) and the polarity is correct (tested the wrong way too but still didnt work).
We tested everything we could think of and the wires ARE giving off the correct power. The camera lights still arent coming on. I plugged it into an ethernet to the clamshell as a last ditch effort but still nothing.
Is there any way to debug or attempt to fix the Axis Camera itself since we know the cables arent the issue, or should I just declare it broken and look for a replacement camera?
Team 3753 BulahBots
Unread 11-01-2013, 11:40
Just Itinerant
If you plugged the reverse power into the camera at any time, then the camera is toast.
Unread 11-01-2013, 14:35
dellagd's Avatar
AKA: Griffin D
Rookie Year: 2011
Are you connecting the camera to a laptop using a crossover cable and setting the laptops ip per the instructions?
Unread 11-01-2013, 14:49
ctccromer's Avatar
Animus
Rookie Year: 2012
Had not tried that yet; wanted to just establish a power connection before i tried anything on the laptop. Will the lights not turn on if it's plugged into the power supply but not my laptop?
Team 3753 BulahBots
Unread 11-01-2013, 15:04
AKA: Nathan Hui
Power light status ring should light up regardless of ethernet signal.
Nathan Hui
FTC 4950, 6038
  #15   Spotlight this post!
Unread 11-01-2013, 17:15
dellagd's Avatar
AKA: Griffin D
Rookie Year: 2011
Based on your agreeing to the photos attached to an above post, Im guessing you're using a M10 series camera.
Manual here: http://www.axis.com/files/manuals/um...40_en_1203.pdf
Anyway, it details the three LEDs on the back on page 8. Are any of these LED's on the back (not the status ring or whatever, which the manual says the M1011 does not have) lighting?
