Go to Post Not all FIRST people are nuts. Some are threaded holes, rivets, velcro, or zip-ties. Anything but duct-tape. - Richard Wallace [more]
Unread 10-01-2013, 13:36
1493kd's Avatar
1493kd 1493kd is offline
kd
FRC #1493 (FALCONS)
Team Role: Teacher
1493kd will become famous soon enough
Entering goal
I looked high and low in the rules and cant find anything about having part of your bot enter a goal. One of our designs is to scoop up the game pieces and dump them in the goal. Part of the bot may enter the goal when dumping. Is there anything against this?
Unread 10-01-2013, 13:44
vinnie's Avatar
vinnie vinnie is offline
FRC #3309 (Friarbots)
Rookie Year: 2010
vinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond repute
Re: Entering goal
It should be in the manual somewhere.
I don't think it is explicitly prohibited, but a relevant rule could be G14
Originally Posted by FRC Manual
G14
The following actions are prohibited with regards to interaction with FIELD elements:
grabbing,
grasping
grappling
attaching to,
damaging,
becoming entangled
Actions A-D do not apply to ROBOT interactions with the PYRAMID.
Just make sure that you don't become entangled in or damage the goal. I would submit this to Q&A though if this is a serious part of your design.
Edit: It may be considered "exiting the field" in which case your robot would be disabled. I would submit this to the Q&A if you are thinking of integrating that idea into your design.
Student (3309) 2010-2013
Mentor (597) 2014
Mentor (3309) 2013-Present
Unread 10-01-2013, 13:47
Greg Young Greg Young is offline
Science Enabler
FRC #0587 (Hedgehogs)
Greg Young has a spectacular aura aboutGreg Young has a spectacular aura about
Re: Entering goal
From the Q&A
Q20 Q. If I put something into the low goal to drop Frisbee's into the goal is it considered leaving the field?
A. There are no Rules that prohibit breaking the plane of the LOW GOAL, however per Rule G12, ROBOTS may not contact anything outside the FIELD.
I suspect that if you contact the chains or the back of the goal you will draw a foul.
I looked for other questions about this and didn't find any. It is probably worth a Q&A about whether the chains are considered part of the field.
To invent, you need a good imagination and a pile of junk. -- T.A.Edison
My wife says I must need to work on the imagination thing.
Unread 10-01-2013, 13:51
1493kd's Avatar
kd
FRC #1493 (FALCONS)
Team Role: Teacher
Re: Entering goal
Thank you now I have to check field drawing to see how far back the chain are.
Unread 10-01-2013, 13:53
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Entering goal
Keep in mind that if the top goals are NOT considered to be part of the field, simply breaking the vertical plane could incur a penalty, or even if the robot doesn't touch the chains, but contacts the inside frame of the goal it could be penalized.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 10-01-2013, 13:58
Science Enabler
Re: Entering goal
I should have checked the rule.
3.2.3.3 G12
Violation: ROBOT will be DISABLED. However, if it occurs during AUTO, and there is no safety concern, the Head
Referee will allow a 10-second grace period at the beginning of TELEOP for the ROBOT to correct the situation.
It sounds like you could survive it during AUTO but it could get you disabled during TELEOP.
You definitely need clarification through the Q&A.
Unread 10-01-2013, 13:50
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
Re: Entering goal
Per the FRC Q&A:
Rule G12 states:
So the question is now, what defines the FIELD.
Per the glossary section of the manual:
FIELD: the area bounded by and including the GUARDRAILS, ALLIANCE WALLS, LOW GOALS, and FEEDER STATIONS.
The definition explicity states that the LOW GOALS are part of the field, thus contacting them would NOT be breaking the field.
However, the MIDDLE GOALS and HIGH GOALS are NOT included in this definition, (and they DO exist in the glossary) so by this definition, if your robot touched ANY part of the goal, it would be a penalty per G12.
You should ask the Q&A for further clarification.
1771- Mentor (2015)
Unread 10-01-2013, 18:39
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Re: Entering goal
Originally Posted by nighterfighter View Post
Per the FRC Q&A:
Rule G12 states:
"FIELD: the area bounded by and including the GUARDRAILS, ALLIANCE WALLS, LOW GOALS, and FEEDER STATIONS."
They include LOW GOALS and FEEDER STATIONS as boundaries of the field because they cut off an angle between the ALLIANCE WALLS and GUARDRAILS. If you reach through a hole in one of the boundaries, or reach over, you can't touch anything outside that boundary.
(since 2004)
Unread 10-01-2013, 19:00
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Re: Entering goal
Someone please correct me if I'm wrong, but if the field includes the low goal and the low goal includes the chains, then the chains are in the field of play and can be touched without penalty. Looking at that logical chain, the only part of which I'm unsure is that the chains are part of the goal.
2.2.3: Each ALLIANCE’S LOW GOAL is located adjacent to the opponent ALLIANCE WALL and to the opponent DRIVERS’ left. The opening of the LOW GOAL is 29 in. wide and 24 in. tall. The bottom edge of the LOW GOAL is located 19 in. from the playing surface of the FIELD.
A DISC is considered SCORED in an ALLIANCE’S GOAL if any part of the DISC has crossed through the opening of the GOAL, is in the GOAL at the end of the MATCH, and is not in contact with any ROBOT from that ALLIANCE.
GOAL: a FIELD element in which DISCS are SCORED to earn points for an ALLIANCE.
LOW GOAL: the GOAL located between a FEEDER STATION and ALLIANCE WALL.
Emphases mine. If DISCS are scored in the GOALS, then the GOAL has an inside, which I believe can be assumed to include the chains. The idea that the GOALS have an opening that is parallel to the field wall suggests that this boundary is only the beginning of the GOAL and that there is more goal past that boundary.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 10-01-2013, 19:11
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
Re: Entering goal
The low goal is defined as part of the field, due to what Gary Voshol stated.
If this definition of low goal IS true, and follows over to high goals, then touching the chains should be legal, assuming the robot does not get entangled.
1771- Mentor (2015)
Unread 10-01-2013, 22:31
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Re: Entering goal
It's certainly worthy of a Q&A: "Are the chains part of the goal and on the field, or are they outside the field?" I'd be happy to be proven wrong.
(since 2004)
Unread 10-01-2013, 22:37
danopia's Avatar
danopia danopia is offline
Logical Awesome
AKA: Daniel Lamando
Rookie Year: 2012
danopia is an unknown quantity at this point
Send a message via AIM to danopia Send a message via MSN to danopia Send a message via Yahoo to danopia
Re: Entering goal
Just going off instinct, I'd have to say that the field ends at the field's walls, as that's how the playing area is measured; the chains are beyond this wall, so they're probably going to be outside of the field. Just an assumption, though.
Unread 10-01-2013, 22:42
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Re: Entering goal
The middle and high goals are both located above the 84" height limit, so no legal robot would be able to enter our touch the chains inside them regardless.
Unread 10-01-2013, 22:57
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
Rookie Year: 2012
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: Entering goal
Why would you want to go in instead of dropping the discs in from just outside?
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
