Go to Post This is not an engineering design challenge, this is a project management and common sense challenge with engineering elements. Don't go out of your way to screw yourself. - PayneTrain [more]
Unread 10-01-2013, 15:51
Dillonboy8 Dillonboy8 is offline
AKA: Dillon Knight
FRC #3603 (Reed City Cyber Coyotes)
Rookie Year: 2013
Dillonboy8 is an unknown quantity at this point
Not sure if updates worked
Hey!
I am running Labview 2011 and was just wondering if it was required to use the Labview FIRST put in the kit. I did all of the updates online, when I open Labview it still says "FRC 2012"
Thanks in advance!
Unread 10-01-2013, 16:01
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Not sure if updates worked
Yes, you'll need to install the version of LabVIEW from the DVD in the Kit of Parts. Then you'll need to install the updates. Follow the directions.
Unread 10-01-2013, 16:12
AKA: Dillon Knight
Rookie Year: 2013
Thanks!
