Go to Post I'll toss this out to stir up the pot: if you need double precision floats for your FRC software, you should re-think what you're doing. - Ether [more]
Unread 10-01-2013, 17:41
DMike
Posts: n/a
Chassis weight
Would anyone have an idea what the average weight would be for a mostly completed chassis. Frame, gearboxes,wheels and motors.
Unread 10-01-2013, 18:26
treffk's Avatar
treffk treffk is offline
botgirl
AKA: Kelli
FRC #1802 (Stealth)
treffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud of
Re: Chassis weight
It all depends on your design, drive train and what you are hoping to accomplish for this years game.
For example my students have calcuated that in motors alone we are going to have about 50 pounds of weight with their current design.
If you are just wanting a defensive bot you wouldn't need nearly as many motors or an elaborately designed chasis. If you are wanting to climb or shoot depending how how you design these systems they could also use motors and gearboxes thus changing the weight for every single team. It's difficult to predict an average weight because everyone's and every teams thought processes are different along with their skill sets.
"If you always says yes, what are your yeses worth?"
Alumna of FRC Team 1802
Unread 10-01-2013, 18:52
DMike
Posts: n/a
Re: Chassis weight
Thanks for the info, our group has been working on a direct drive mecanum system. The frame, gearboxes, motors and wheels weigh 47 lbs with a perimeter of 108 inches. I am not sure we want to cheese out the frame any more than it is. At this point it only exists in SolidWorks.
Unread 10-01-2013, 19:29
treffk's Avatar
botgirl
AKA: Kelli
FRC #1802 (Stealth)
Re: Chassis weight
That's okay! Ours only consists in to scale drawings and a 1/3 scale cardboard cutout.
Unread 10-01-2013, 23:15
pmangels17's Avatar
pmangels17 pmangels17 is online now
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
Team Role: Mechanical
Rookie Year: 2011
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Re: Chassis weight
Our drive generally averages around 30-40 pounds. However, in 2011 we built a crab drive (with freshman builders and one sophomore, might I add) that weighed approximately 50 pounds. However, you could easily make a lighter custom one or a lighter one using the kitbot. It all depends on your goals.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 10-01-2013, 23:58
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Donut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond repute
Re: Chassis weight
I think the average is in the 30-40 lb range. We did Mecanum last year with very large standoffs and full size Toughboxes for each wheel (read: overkill) that weighed in at a whopping 60 lbs for the frame, wheels, gearboxes, and motors. This year we're trying out the Nanotubes from Andymark and the new Mecanums from VexPro, I think it should weigh in at around 30 lbs for it all.
Mecanum systems will tend to be a little on the heavier side due to significantly heavier wheels and an extra pair of transmissions. Direct drive should help keep the weight down some without chain or belt needed. Are you using stock gearboxes from Andymark or VexPro, or are these custom? There are quite a few low weight transmissions out there now that can save you some weight.
FRC Team 498 (Peoria, AZ), Student: 2004 - 2007
FRC Team 498 (Peoria, AZ), Mentor: 2008 - 2011
FRC Team 167 (Iowa City, IA), Mentor: 2012 - 2014
FRC Team 2662 (Tolleson, AZ), Mentor: 2014 - Present
Unread 11-01-2013, 00:09
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Re: Chassis weight
My Chassis' on average weigh about 40lbs. Try to keep it under that.
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 11-01-2013, 06:31
pmangels17's Avatar
AKA: Paul Mangels
Rookie Year: 2011
Re: Chassis weight
The shifter transmissions we ordered this year were around 8 pounds with a motor and shifting cylinder installed. However, we took off the side plates and replaced it with the star shaft that comes in the kitbot, and dropped a pund already between the two. THere are also some extraneous mounting brackets that could be cut, and some holes in the side plate (or thinned out areas) that could be taken out for more savings, but we will probably keep the plates stock. We are only using to drive transmissions this year, so we should be okay. Transmissions make up a huge part of your weight, so consider your power distirbution wisely.
Unread 11-01-2013, 09:00
DMike
Posts: n/a
Re: Chassis weight
We are planning a .080 5052 box style chassis, the gear boxes are a modulox inspired design with Aluminum gears and shafts. We went with an 8 inch wheel due to clearance issues with the 6's. The wheels alone are 10 lbs. I also made an error our weight at this point is 44 with the motors.
Unread 11-01-2013, 09:12
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
Rookie Year: 2011
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
Re: Chassis weight
47lbs is quite heavy, though you should avoid cheesing it out just yet. First finish CADDing the whole robot and see whether you pass the weight limit or not. If you don't, it'll be better keeping the chassis heavy than cheesing it out and losing structural strength.
Team FRC#2212 The Spikes, 2011-...
Builld leader 2013
Drive coach 2012-2013
Mentor 2015-...
Unread 11-01-2013, 10:11
Peter Matteson's Avatar
Peter Matteson Peter Matteson is offline
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Peter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond repute
Re: Chassis weight
Our lightest most basic and optimized 4 motor, 2 speed, drop center 6WD in that state was 35 lbs. Our articulated drivetrains tend to be about 10-15 lbs heavier. I would say anything in the 40 lbs range is normal.
2011 Championship Finalists/Archimedes Division Championships w/ 2016 & 781
2010 Championship Winners/Newton Division Champions
Thank-you 294 & 67
2009 Newton Division Champions w/ 1507 & 121
2008 Archimedes Division Champions w/ 1124 & 1024
2007 Championship Winners/Newton Division Champions w/190, 987 & 177 The Wall of Maroon
2006 Galileo Division Champions w/ 1126 & 201
www.bobcatrobotics.org
"If you can't do it with brains, it won't be done with hours." - Clarence "Kelly" Johnson
Unread 11-01-2013, 10:22
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Chassis weight
We weighed our practice chassis yesterday. Without the second gearbox, two CIMs, and cross-frame support, it came to 25 pounds. I'm guessing it'll be just under 40 pounds with all structure and motor speed controllers installed, before adding the brain box.
Unread 11-01-2013, 13:56
LightSpeedIII's Avatar
LightSpeedIII LightSpeedIII is offline
Ludicrous Speed!
AKA: Bradley J.
FRC #1086 (Blue Cheese)
LightSpeedIII is an unknown quantity at this point
Re: Chassis weight
According to our CAD, our drivetrain should weigh approximately 25lbs.
Looks like they've gone to plaid!
Unread 11-01-2013, 14:11
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Re: Chassis weight
Did you take into account the 5 lbs or so of bolts, nuts, and washers that usually come together with a chassis? As well as each motor's actual weight?
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
  #15   Spotlight this post!
Unread 11-01-2013, 14:14
Chris is me's Avatar
Chris is me Chris is me is online now
AKA: Pinecone
Re: Chassis weight
I think this is a really bad idea. Those hex shafts are designed to be used as spacers, not as drive axles. That part could easily fail when you need it the most.
Spend your weight where it matters. The drivetrain matters.
