Go to Post FIRST is difficult and it is challenging, but you aren’t necessarily required to go off and build an 8 motor drivetrain and 4 motor / 8 pneumatic piston arm mechanism for the heck of it when a 2 motor non-shifting drivetrain and 2 motor arm does just as good a job. - Bill Gold [more]
Unread 11-01-2013, 13:56
LightSpeedIII's Avatar
LightSpeedIII LightSpeedIII is offline
Ludicrous Speed!
AKA: Bradley J.
FRC #1086 (Blue Cheese)
LightSpeedIII is an unknown quantity at this point
Re: Chassis weight
According to our CAD, our drivetrain should weigh approximately 25lbs.
Looks like they've gone to plaid!
Unread 11-01-2013, 14:11
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Re: Chassis weight
Did you take into account the 5 lbs or so of bolts, nuts, and washers that usually come together with a chassis? As well as each motor's actual weight?
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 11-01-2013, 14:55
Ludicrous Speed!
AKA: Bradley J.
Re: Chassis weight
If I'm not mistaken (and I very well may be), the frame will be welded together, leaving the only bolts, nuts and washers on the frame being used to mount the gearboxes and modules. That weight should include motors, but in the event that it doesn't, adding the weight of 4 CIMs to the 25lb approximation would put it at just a little over 36 pounds.
