Go to Post Keep your chin up, your safety glasses on, and don't let the magic smoke out of the electrical components and you'll do just fine :) - rsegrest [more]
Unread 10-01-2013, 18:19
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Transfer gearbox output at a 45° and 90 °angle?
A concept I had for climbing the pyramid involves getting power from the drive motors. It's based on our current climbing concept which I won't explain beyond saying that it involves 2 wide belts in the shape of a V and are at 45 degrees to the frame. The attached image shows my idea to transfer power from the drive train to the belt. What I don't have ideas on how to do are the circles with question marks in them. I don't have an idea on how to transfer power along those angles with enough torque to lift the robot. Thoughts?
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 10-01-2013, 18:32
Alex.q Alex.q is offline
FRC #2220 (Blue Twilight)
Alex.q is on a distinguished road
Re: Transfer gearbox output at a 45° and 90 °angle?
The most obvious solution to me would be to use bevel gears. In FIRST, they are often used on swerve drive modules to transfer power from a vertical shaft to a horizontal one. I know they can transfer power at 90 degrees, but I'm not sure if there a bevel gears for a 45 degree angle. Bevel gears have pretty high tolerances though to keep them together. One other option which I don't know much about would be something like a universal joint (wikipedia or google image search).
Unread 10-01-2013, 19:10
cgmv123's Avatar
AKA: Max Vrany
Rookie Year: 2011
One thing I forgot to put in the drawing is that I'm planning on putting a secondary gearbox somewhere on the shaft, as climbing speed doesn't need to be as fast as driving speed and the extra torque will help with climbing.
Unread 10-01-2013, 19:28
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Look into Power Take-off systems.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 10-01-2013, 19:34
JakeD's Avatar
JakeD JakeD is offline
FRC #0360 (The Revolution)
Rookie Year: 2007
JakeD will become famous soon enoughJakeD will become famous soon enough
The other option is the universal joint.
en.wikipedia.org/wiki/File:Universal_joint.gif
A quick google search should show you some examples. Though I will admit I don't know where you could buy one off hand and its not the simplest mechanism to machine in the world.
