Go to Post the bang for the buck is unparalled. Where else can $6000 change an entire group of student's lives forever? - Cory [more]
Unread 10-01-2013, 18:51
ming08108 ming08108 is offline
FRC #4795
ming08108 is an unknown quantity at this point
Jaguar problem
We connected one jaguar and the motor would only spin one way.
We swapped the jaguar with another one then it worked, is this a common problem or did we do something wrong?
Is our jaguar defective?
Unread 10-01-2013, 18:53
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Re: Jaguar problem
Are both limit switch jumpers in place on the jaguar with the issue? They are located on the right side of the set of ports on the front of the controller. Compare the two controllers if you're unsure.
This was a common failure mode of the grey jaguars but based on your team number I'd have to imagine you're referring to a black jag
Unread 10-01-2013, 18:56
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Jaguar problem
Can you describe what the LEDs on both the good and the "bad" jaguar do when you command forward and reverse?
Unread 10-01-2013, 19:02
FRC #4795
Re: Jaguar problem
Had not thought of the jumpers will check that tomorrow!
Unread 10-01-2013, 19:03
FRC #4795
Re: Jaguar problem
I cannot remember off the top of my head, Will post a picture tomorrow.
Unread 12-01-2013, 13:09
jackieann jackieann is offline
FRC #0281
jackieann is an unknown quantity at this point
Re: Jaguar problem
Okay so I havea question is it legal to mount electrical components such as jaguars on like aluminum? I havent found any rule against it but does anyone know for sure?
Unread 12-01-2013, 13:34
dudefise dudefise is offline
FRC #2637 (Panthers)
Rookie Year: 2011
dudefise is an unknown quantity at this point
Re: Jaguar problem
Yes, you can mount jaguars, as well as many other electronic components on metal as their cases are isolated. The cRio and camera cannot be mounted on aluminum as their cases are grounded and the robot frame would not be isolated.
2010 VRC 2453B - Team Captain
2011 FRC 2637 - Electrical - Las Vegas Regional Semifinalists with 1726 and 166
2012 FRC 2637 - Electronics Captain - Las Vegas Regional Semifinalists with 1661 and 2984
2013 FRC 2637 - Build Captain - Inland Empire Quarterfinalists with 3925 and 207
2014 FRC 2637 - College Mentor - Central Valley Quarterfinalists with 2085 and 5136 / LA Regional Semifinalists with 696 and 5102
2015 FRC 2637 - Lazy Schmuck - Couch Sitting Quarterfinalist
2016 FRC 2637 - College Mentor - SD Regional Finalist with 1572 and 2443, Excellence in Engineering, Wildcard
