Go to Post One wouldn't want to keep the red herring in hand, that gets kind of stinky. - GaryVoshol [more]
Unread 10-01-2013, 19:28
Ganondalf Ganondalf is offline
FRC #4665
Ganondalf is an unknown quantity at this point
Unhappy Deploying robot for the first time.
Hello, so I am trying to deploy my robot. I have set the IP's and everything. I have tested my code with the simulator. In fact, everything should be fine... "should be." When I deploy my robot through the Robotmain.vi there weren't any errors and it successfully deployed. I closed out of the deploy window and the Robotmain screen had changed, a little black arrow now appeared and said that it was "running." However, when I went to use the joysticks, nothing happened. Do I have to change anything so it works with Teleop? Like an enable switch... or maybe disable autonomous? Oh, and everything connected to the cRIO appears to be working just fine, the two jaguars have blinking orange lights.
Allons-y!
Unread 10-01-2013, 19:33
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Re: Deploying robot for the first time.
You have to connect to the robot with the FRC Driver Station software, set the mode to teleop and enable it: http://wpilib.screenstepslive.com/s/...abview-program (Running the Program step)
Unread 10-01-2013, 19:42
FRC #4665
oh my... I love you. I'm facepalming right now lol
Unread 10-01-2013, 20:24
Ido_Wolf's Avatar
Ido_Wolf Ido_Wolf is offline
LabVIEW Addict
AKA: Ido
FRC #2230 (General Angels)
Rookie Year: 2011
Ido_Wolf is an unknown quantity at this point
Please note that it's possible (and eventually necessary...) to run the code without LabVIEW opened, if you build&deploy it and then set it to run as startup.
