Re: Designing a climbing mechanism for 2013... a humbling experience
That's true for us, too. Once we're at two, going to three should be essentially a repeat of what we just did... (And to answer the question, we should be able to climb an arbitrary number of levels given time and battery life.)
We think we have a solution. Of course, I thought that a few days ago, also.
The challenge is significant, the answers will probably be subtle adjustments to a solid concept. The biggest problems are initial docking (we want it to be simple, quick, robust, and tolerant of poor angles of approach), transitioning from level 1 to level 2 (once you have that, 2-3 is rinse and repeat), and getting all the way up to the top of level 3, so that you are totally above level 2. Rolling off the post and flipping over backwards are certainly problems. CG will be critical in the climb. And you must really double check all the geometries out. Is it risky? Yes. Is the risk worth the reward? We think so. |
Another challenge for some may be the 54" radius. Unless I'm misreading from the Q&A, that is with respect to the floor - so if your robot inverts, it needs to do so inside of a 54" cylinder. They certainly didn't make this a trivial challenge this year.
One of the more challenging 'size' restrictions we've had. |
Here is our plan that we are trying to flesh out
https://docs.google.com/file/d/0B44TPv-TccPZTTVWLUV0Z0JlM1U/edit Hope it works |
Our concept it somewhat of a "Monkey Bar climbing" approach.
Here is a quick video I threw together yesterday to demonstrate the basic concept to our team. Please excuse the extra enthusiasm I exhibit towards it's potential success, I'm just excited we have something that might work. http://youtu.be/9kxMmYTVo0E |
How would you rotate/tilt the bottom half of the bot without applying torque to the horizontal pipe. Tilting or rotating the bottom half of the bot on a unfixed upper point would just change the c.o.g and swing it under the bar further. I think ???
After pounding our head at it a few days, we have 2 designs that we think are within our team's fabrication abilities. I would argue that only one of them is simple but that is an opinion. We're building prototypes of them now and won't know how truly well they work until probably Tuesday next week.
I think "simple" is a relative term for the 30 point climb. A "simple" mechanism for climbing could still have quite a bit of movement. |
Yes, we have a design that is simple, fits a small footprint and potentially will climb to the top in <20 seconds. It should in theory be able to climb to any level without any change.
#10
- Sunny G. |
#11
If it can make it to the top when we build it, it can make it to any level. The design does not require changes based on levels, we just have to be careful when building it. A simple error when building could provide quite a headache for us when trying to climb.
#12
I wonder how many of the 'simple' ideas people profess to have were things we considered and dismissed as being too unreliable, too unpredictable or not simple at all.
We have shied away from anything that relies on the machine's center of mass being in a known, good location or from manipulating that center of mass to encourage the robot to swing into some other orientation. There are too many unknowns there for me to be comfortable putting considerable effort into such a system. We have some ideas for climbing up the corner that do not require manipulating our CoM, but they have their own challenges. We are likely going to focus instead on frisbee manipulation -- the potential for incremental improvement in that aspect of the game seems more promising to us than the potential, fixed 30/50 pt. contribution. |
#14
There are so many dependencies that affect every aspect of your robot. This is the hardest task we've ever been asked to do and I will bet money there are no more than 30 teams in all of FIRST that do it in an official match. |
#15
And far less will do it in a reasonable amount of time.
