Go to Post FRC competitions are fun, people. If you honestly need a video game system to keep you interested, you're ignoring a tremendous experience. - Mr. Pockets [more]
Unread 15-01-2013, 09:13
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Designing a climbing mechanism for 2013... a humbling experience
Originally Posted by rinim324 View Post
Can i get an expert opinion on a design that uses a three stage arm which extends via a pulley system but retracts using a winch powered by a toughbox? The Stages are 27in long with 8in of overlap.
Do you want an opinion on the legality of it? or whether or not such a mechanism could work?
Either way, we'd need a lot more information about the design.
Unread 16-01-2013, 09:16
rinim324's Avatar
rinim324 rinim324 is offline
FRC #2171 (Robodogs)
Team Role: Mechanical
Rookie Year: 2010
rinim324 is an unknown quantity at this point
Smile Re: Designing a climbing mechanism for 2013... a humbling experience
Whether or not it would work. We actually revised it a little to have 3 stages and a slider peice on the end with hooks attached to it. The robot is designed to be a corner climber. The arm fully retracted fits inside the robot frame but fully extended can reach 38inches. The Arm is fixed on the frame at 60 degrees (The corner posts are 60 degrees relative to the floor not 68 like the sides). We extend the lift arm with a simple pulley mechanism but retract it with a winch that has the cable hooked to the outermost stage and pulls down at 60 dgrees parallel to the The Arm. We also have a wheel mechanism at the bottom of the robot that rides the vertical post as a third point of contact and it is designed to sort of "walk" over the corners of the horizontal bars. Once the arm is retracted fully two sets of hooks mounted to the frame will latch on to the horizontal bar while the arm extends to the next level.
I hope this is the info you would need.
Unread 16-01-2013, 10:45
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Originally Posted by Kevin Sevcik View Post
So just to keep everyone in the thread updated, Team Update 1-15-2012 has suddenly made climbing a rather lot easier. The 54" cylinder is now robot relative while you're touching the pyramid. Which obviously makes many mechanisms and methods a lot more viable.
My condolences to those of you who have already locked in a more restricted, less robust design based on yesterday's rules.b
In your opinion the rules forced a less robust design. I disagree. We had a nice robust design that even the most conservative members of our team were happy with. Now it's illegal.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 18-01-2013, 12:36
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
This is an interesting concept, and has similarities to our plan.
By "3 stages" do you mean 3 parts that move, in addition to the fixed end? That is complexity that can be difficult to put into operation. Depending on how you use the pulleys to move the last stage, that could add up to a lot of torque on the first stage. Without seeing a drawing, that would be hard for us to evaluate. But it sounds good, and I hope it works for you.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 21-01-2013, 18:41
IceStorm IceStorm is offline
Mentor FRC 5046, FTC 8688
AKA: Chad
FRC #5046 (Jacked Up Jackets)
IceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of light
Send a message via AIM to IceStorm Send a message via Yahoo to IceStorm
Originally Posted by wireties View Post
Perhaps a heavy lift quad-copter that reaches out and taps each horizontal pipe, dumps 4 blue/red discs and hovers in level 3? ;o)
Might have a big issue with bumper rules during the rest of the match though. That is unless you can hover really low to the ground.
Not to mention you better latch on before the timer reaches 0 and they disable all the motors.
Though I would seriously love to see a robot try this.
Unread 23-01-2013, 11:29
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
Those darn bumpers always mess up the design! Perhaps we can just have bumpers that stay on the ground after lift-off. And you are correct, we need a clamp for the EOG power loss.
I was kidding of course (about the quad copter) ... our climber goes up the corner (we hope) using 2 CIMS configured something like a cog train. And the design effort is humbling, especially for a EE!
Fast, cheap or working - pick any two!
Unread 23-01-2013, 19:08
Justin Shelley's Avatar
Justin Shelley Justin Shelley is offline
FRC #3885 (Shockers)
Team Role: Driver
Rookie Year: 2012
Justin Shelley is on a distinguished road
Send a message via MSN to Justin Shelley
Our team has developed a way to score 18 in auto. Up to 42 in teleop. Climb to 30. Dump 20 in top goal. It is important to remember that you can not score in the pyramid during auto. Also you can only posses 4 disc, ever. That includes when climbing and dumping!!! I predict that at championships we will see 200-300 point matches. I also predict our robot will score 110 at best and rarely bellow 68.
Unread 23-01-2013, 19:40
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Team Role: Leadership
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
Originally Posted by Justin Shelley View Post
Our team has developed a way to score 18 in auto. Up to 42 in teleop. Climb to 30. Dump 20 in top goal. It is important to remember that you can not score in the pyramid during auto. Also you can only posses 4 disc, ever. That includes when climbing and dumping!!! I predict that at championships we will see 200-300 point matches. I also predict our robot will score 110 at best and never bellow 68.
I love your confidence. Keep in mind this is a very dynamic and complex game. To say that your robot will never score below 68 points is quite a statement. Be careful where you set your goals and expectations.
Good luck
Justin
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
Unread 23-01-2013, 19:41
45Auto's Avatar
45Auto 45Auto is offline
FRC #2992
45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future
Wow! Someone is in for a RUDE awakening!
2007 - Rookie All Star - Bayou Regional (1858 - Tyborgs)
2009 - Rookie All Star - Bayou Regional (2992 -Prometheus)
2010 - Champions - Bayou Regional (2992 -Prometheus)
2012 - Finalist - Bayou Regional (2992 - Prometheus)
team2992.com/design.php
Unread 23-01-2013, 19:52
Team Role: Driver
Rookie Year: 2012
what seems so crazy about this? I understand 110 is pretty far fetched, not impossible, but 68 i believe will be common at championships.
Unread 23-01-2013, 19:56
45Auto's Avatar
FRC #2992
I guess we'll see in a couple of months!
Unread 24-01-2013, 01:16
nicholsjj's Avatar
nicholsjj nicholsjj is offline
AKA: John Nichols
no team (Devil Bots)
Team Role: Coach
Rookie Year: 2011
nicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant future
What Justin is saying is that we think we can successfully climb while also being able to shoot in autonomous. The 20 pt. dump is in the early stages of prototyping. I'm really excited by the team's enthusiasm this year, but realistically I am having many sleepless nights due to the vision of Thunderbolt falling from the pyramid.
I will say that this is probably the most difficult game element that I have ever heard of in FIRST (well beating 71 in Zone Zeal isn't quite a game element). I also realize that our team has developed a design that I believe will climb well. We were able to keep our shooter on Thunderbolt, but at the cost of giving up floor pick up. I would like to wish every team a successful Season in 2013, and hopefully Team 3885 can compete in St. Lou twice this year. (with a little luck)
2011-FRC Team 3862, Team Captain
2012-FRC Team 3862, Strategy Mentor
2013-FRC Team 3885, Programming Mentor, Razorback Regional, Curie Inspector
2014- FRC Team 3885, Programming Mentor, Arkansas Regional, Newton inspector
2015-??? Teacher Murphysboro High School
“They call it coaching but it is teaching. You do not just tell them…you show them the reasons.”- V. Lombardi
Unread 25-01-2013, 00:59
rocknthehawk's Avatar
rocknthehawk rocknthehawk is offline
AKA: Aaron
FRC #1768 (Robo Chiefs)
rocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to behold
I've been hitting my head against a wall trying to solve this. The pyramid is one of the most difficult elements I've tried to solve in my ten years. The size constraints, combined with the zone rules, make it extremely challenging.
Our students decided a third level climb was highest priority. I was concerned about the 2010 bot; Too much focus on the endgame, to the point we could barely score in teleop. We've had a few different concepts, with way more development than I anticipated.
With that said, we finally got our climber working. We did a proof of concept to climb to the second and touch the top bar, just need to finish our mechanism and it will be fully functioning and scoring on the 30 point bar by the weekend.
Unread 25-01-2013, 08:02
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Pics & Videos or it doesn't exist.
GitHub
  #15   Spotlight this post!
Unread 25-01-2013, 10:54
mikegrundvig mikegrundvig is offline
FRC #2410 (Metal Mustangs)
Rookie Year: 2012
mikegrundvig is an unknown quantity at this point
Our climber design has been plagued by complexities in supporting it as well as clearance problems getting it to grab bars but not touch the box on the top of the pyramid as well as having enough room to support minor alignment issues.
-Mike
