Go to Post ...I'm still waiting for a Chiefdelph-aholics group to form at the local YMCA. - KelliV [more]
Unread 11-01-2013, 10:46
purduephotog purduephotog is offline
Active Defense Design Engineer
AKA: Jason
FRC #3015
Team Role: Leadership
purduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the rough
Send a message via AIM to purduephotog
360 Degree, Rotating post launcher
I have this idea....
So the paper model isn't the best, and I'm having trouble deciding how best to support the inner ring since I would expect a 1cm gap between the slick material and the rotating post.
Also the outer edges are rubber to increase traction. The unit is fed through the bottom (probable piston) and exits the top. The exit chute is angled slightly (which may be cut down depending on the effect of spin).
I originally was envisioning the unit as about 4 Frisbee thick (A new official unit?), in order to accommodate an unsupported inner gap from flexing. Obviously if the material is stiff enough it won't deflect under loading. Some sort of iso-beam bottom would suffice for that, so long as the outer rim is secure enough.
With a full 360 degrees of rotation to accelerate the Frisbee I've got to imagine this would be even more efficient and accurate than the 180 degree shooter.
Elevation and rotation can be centered about the rear axis.
Unfortunately I've exhausted my drawing capability. I failed stick art 101.
Comments?
ID:	13465  Click image for larger version
http://purduephotog.deviantart.com
Portrait Photography: "I used to say Immortalized in Silver, but now I say Captured and Squeezed by Electrons".
Unread 11-01-2013, 11:03
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Re: 360 Degree, Rotating post launcher
It's basically an Archimedes screw, but going faster in order to shoot, correct? I would definitely prototype something for this, but also keep in mind the *sheer size of the end result. Say you use a 2" inner post. That's going to be at least a 2' cylinder, not including outer thickness.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 11-01-2013, 11:17
AKA: Jason
FRC #3015
Originally Posted by CalTran View Post
It's basically an Archimedes screw, but going faster in order to shoot, correct? I would definitely prototype something for this, but also keep in mind the sheet size of the end result. Say you use a 2" inner post. That's going to be at least a 2' cylinder, not including outer thickness.
Yup. A theoretical exit velocity of 15 mph at least, if the math holds. A larger post, 45mph, but that requires more space and exceeds the width requirement.
Of course it could be spun faster at a smaller size to take advantage of the additional contact and acceleration time.
Hrmm... interesting thoughts.
Unread 11-01-2013, 11:45
CalTran's Avatar
Missouri S&T Senior
Rookie Year: 2010
Why 360 degrees of rotation and not 1440 degrees of rotation? The latter would make for a taller cylinder. Or, some amount of rotation between those two numbers. Funnily enough, if you want to pursue an Archimedes Screw, you can look at a couple of designs from 2009, Lunacy, and modify them from orbit balls to frisbees.
Unread 11-01-2013, 12:05
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
If the rotation is increased, then I could see this being a very good storage and shooter-all-in-one type of mechanism. We played with an idea similar to this last year and called it a "dead stop shooter" because it accelerated from "dead stop" to full speed by the time the balls left the shooter.
The issue we had was that we inevitably still needed a loading roller to keep the balls in the robot and it ended up not being able to save us any complexity at the loss of range because the shooter was based much less on Ke.
Best of luck. Let us know how it goes.
-Jeff
Also wanted to add:
The designs used in 2009 (or 2006 for that matter) will provide good reference, but should not be emulated. Remember that in 2009 many teams ran 2-3 inches of compression throughout the system. It can be very difficult to create a spiral that can keep a constant 1/8-1/4 inch of compression (which is what seems to work for Frisbees)
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
