Go to Post A good driver will always win over a good robot. - Mike Norton [more]
Unread 11-01-2013, 11:36
Or 2230's Avatar
Or 2230 Or 2230 is offline
FRC #2230 (General Angels)
Team Role: Coach
Or 2230 will become famous soon enough
CIM motors
Hello !
My team (2230) is using 6 CIM motors this year:
1 CIM for shooter, 1 CIM for climbing and 4 CIMs for our drive system.
Do you recommend us to split the motors differently?
And what motors does your team use?
Unread 11-01-2013, 11:40
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Re: CIM motors
Originally Posted by Or 2230 View Post
Hello !
Watch the gear reduction to make sure you can actually climb effectively. This way you will not overload your motors.
Assuming you do not drive and climb at the same time, you should be in good shape. The load that is on the shooter will likely be minimal by comparison.
I would make the assumption that most teams are using this set up this year. If not I will be very surprised.
Batteries will die faster than usual this year, so make sure you have at least 4 batteries when you go to competition! More batteries = more time to charge!
Unread 11-01-2013, 11:51
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: CIM motors
1 CIM motor, properly geared, is perfectly capable of lifting a robot - we did it in BreakAway that way. It wasn't the fastest climb in the world, so we're looking at ways to get some more power into it for this challenge!
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 11-01-2013, 13:13
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: CIM motors
I would think so.
Maybe you don't need a CIM on the shooter wheel, and you could use 2 on the climber. Has anyone tried one of the lesser motors on the shooter with successful results ?
Unread 11-01-2013, 13:30
billbo911's Avatar
billbo911 billbo911 is online now
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Re: CIM motors
The Mini CIM looks to be close enough to the standard CIM with respect to it's specs. to be used for the shooter. Granted, you will loose some of the rotational inertia provided by the armature. But, a good control algorithm just might overcome that.
---------Free RPM---Stall Torque----Stall Cur---Free Cur-----PWR
Mini CIM---6200--------1.40Nm-------86.0A-----1.50A-----227.24W
We will be testing the Mini CIM in our shooter soon.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 11-01-2013, 13:33
Ether's Avatar
Rookie Year: 1969
Re: CIM motors
Originally Posted by billbo911 View Post
We will be testing the Min CIM in our shooter soon.
Smile.
Do you guys have a clamp-on ammeter? Could you measure the current draw for both the CIM and the mini CIM while at the desired wheel speed ?
Unread 11-01-2013, 14:05
billbo911's Avatar
Re: CIM motors
Originally Posted by Ether View Post
Smile.
I know you've seen the video's we posted already. Did you see the server rack power supply we were using? Fortunately it has an integrated Vout meter and an Iout meter. I will see if I can get those values this evening. These will be free speed values only. I truly doubt the metering circuit can display the actual current drawn when the Frisbee passes through the shooter.
We have seen the current jump from 3A range to 10A+ and back down with the CIM and a 6in wheel, but I doubt it is accurate.
More data to follow.
Unread 11-01-2013, 14:22
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Re: CIM motors
The Mini CIM is looks to be close enough to the standard CIM with respect to it's specs. to be used for the shooter. Granted, you will loose some of the rotational inertia provided by the armature. But, a good control algorithm just might overcome that.
You have the Mini-CIM and the BAG motor confused. The BAG motor is last on the motor chart. The Mini-CIM is next to last. (The BAG Motor is the bigger of the two.) Don't fret, I mixed up the 2 at first as well.
That said, I like the BAG motor for shooting as well. You're allowed 4, so ganging 2 together comes close or even exceeds the specs of a CIM. Keep CIM's for driving and climbing.
Nevermind
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 11-01-2013, 14:27
Domtech's Avatar
Domtech Domtech is offline
I Do Everything
AKA: Dominic
FRC #2412 (Robototes)
Domtech is an unknown quantity at this point
Re: CIM motors
According to this page the BAG motor is the smaller one.
EDIT:
Also, the mini CIM is 2/3 power of a CIM at a slightly higher max rpm.
I feel they should work great for shooters.
Re: CIM motors
Double check that...
Mini CIM: http://www.vexrobotics.com/vexpro/mo.../217-3371.html
P/N: 217-3371
Size: 2.5” [63.5 mm] diameter, 3.36” [86 mm] long
Specification
Free Speed: 6,200 rpm (+/- 10%)
Free Current: 1.5A
Maximum Power: 230 W
Stall Torque: 12.4 in-lbs [1.4 N-m]
Stall Current: 86A
Mounting Holes: (4) #10-32 tapped holes on a 2" bolt circle
BAG motor: http://www.vexrobotics.com/vexpro/mo.../217-3351.html
P/N: 217-3351
Size: 1.59” [40.4 mm] diameter, 2.72” [69 mm] long
Specification
Free Speed: 14,000 rpm (+/- 10%)
Free Current: 1.8A
Maximum Power: 147 W
Stall Torque: 3.5 in-lbs [0.4 N-m]
Stall Current: 41A
Mounting Holes: (2) M4 tapped holes on a 25mm bolt circle
The Mini-CIM is bigger and more powerful than the BAG motor, although that power comes at higher torque and less free speed.
Unread 11-01-2013, 14:29
John's Avatar
John John is offline
AKA: John Gillespie
FRC #1153 (Roborebels)
Team Role: Mechanical
John is just really niceJohn is just really niceJohn is just really niceJohn is just really niceJohn is just really nice
Re: CIM motors
Not according to the VEX website. BAG motor is 217-3351, miniCIM is 217-3371.
Unread 11-01-2013, 14:32
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Re: CIM motors
Maybe we should just call them grandpa CIM, father CIM, and baby CIM.
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 11-01-2013, 14:36
billbo911's Avatar
Re: CIM motors
Ah, but don't forget the Great Grandpa "Mini bike motor" CIM from a few years back.
Unread 11-01-2013, 14:37
Domtech's Avatar
I Do Everything
AKA: Dominic
Re: CIM motors
Our team has been referring to the BAG motor as the micro-CIM
  #15   Spotlight this post!
Unread 12-01-2013, 00:23
billbo911's Avatar
Re: CIM motors
As promised, here is some very raw data. This is a comparison between the CIM and Mini CIM driving the same system.
In a nut shell, the the Mini CIM draws more current at the same voltage.
