Go to Post I just got pwned by Dave...how awesome is that?! - Tetraman [more]
Unread 11-01-2013, 13:39
crollison crollison is offline
AKA: Chris Rollison
FRC #4809 (Black Knight Robotics)
Team Role: Coach
crollison is an unknown quantity at this point
Labview control motor with buttons
Could somebody send me a screenshot or something to show me how to program a motor to buttons on the joystick. Just working through programming and wanted to see how to do this, followed one youtube video and it doesn't work. I'm pretty sure that I have everything correct in the begin.vi, it's the telop.vi that I'm having problems with.
Thanks.
Unread 11-01-2013, 16:29
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Labview control motor with buttons
Search the forums for "motor button" and you'll find lots of suggestions. Here is a good one.
Unread 11-01-2013, 22:51
propionate's Avatar
propionate propionate is offline
Team co-lead and LabVIEW programmer
AKA: Stephen
FRC #1732 (Hilltopper Robotics)
propionate is on a distinguished road
If Alan's code doesn't resolve the issue, you could try these things in the following order (testing your motor in between):
1. Make sure that you're "opening" the motor and joystick in the begin.vi so that teleop can recognize the refnum's (in the most basic terms, the refnum is a label for any input/output device in LabVIEW).
2. Make sure that the refnum's for the motor and joystick in the begin.vi match those in the teleop.vi
3. Create an indicator on your joystick's button cluster, then deploy directly from the laptop. Press your desired buttons on the joystick and watch to see if they light up their respective indicators on the teleop.vi front panel. If not, reply with results.
