Go to Post In FIRST you have the right to remain silent, anything you say can and will be held against you and your associates in the court of public opinion. - Koko Ed [more]
Unread 11-01-2013, 18:29
gluxon's Avatar
gluxon gluxon is offline
\n
AKA: Brandon Cheng
FRC #0178 (The 2nd Law Enforcers)
Team Role: Leadership
Rookie Year: 2011
gluxon has a spectacular aura aboutgluxon has a spectacular aura aboutgluxon has a spectacular aura about
[2013] SocketException in Netbeans during code deploy
My team is struggling with a strange error when deploying code. We get a java.net.SocketException error when Netbeans attempts to connect to the FTP server on the cRIO.
This was after we updated all our software with the 2013 Java and Labview update. We're using the 2013 Driver Station, sunspotfrcsdk, and the latest version of JDK from Oracle.
I tested with a separate machine still under last year's utilities, and that uploaded fine. I then updated only the Netbeans plugins for 2013 on that machine, and then got a cRIO image mismatch. No biggy, just update to the 2013 v47 image. After I did that, I began receiving the same error.
Strangely enough, I downloaded FileZilla to test if the FTP server was working. It connected to the address fine.
Here's a link to the log saved from Netbeans. Any help would be greatly appreciated.
http://pastebin.com/na26vENM
