Go to Post I'm exceptionally bad at taking my own advice, is all. - Libby K [more]
Unread 11-01-2013, 19:20
Regis3550 Regis3550 is offline
FRC #3550
Regis3550 is an unknown quantity at this point
Question Problem deploying code on Ni cRIO-FRC I
Hi everyone!
I recently installed FRC Labview 2013 and tried to deploy a program on our NI cRIO-FRC I (old version). I unfortunately got the following errors:
-Errors were detected in the target log when connecting to the target:
LabVIEW: VI version is too early to convert to the current LabVIEW version.
Select "Apply" to ignore these errors and continue with deployment.
I selected "Apply", then after a while I got this:
-Deploying IMAQ CreateIMAQ Create loaded with errors on the target and was closed.
LabVIEW: Failed to load shared library nivissvc.*:LV_Create:C. Ensure that the library is present on the RT target. Use MAX to install NI software or FTP to transfer custom libraries to the RT target.
Deployment completed with errors
Can anyone have an idea of how to solve this?
Thank you.
Regis
Unread 11-01-2013, 19:55
blackflame2996's Avatar
blackflame2996 blackflame2996 is offline
Alumni
AKA: David Donahue
FRC #2996 (Cougars Gone Wired)
Rookie Year: 2011
blackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to all
Re: Problem deploying code on Ni cRIO-FRC I
Do you have the latest firmware version on the cRIO?
2009 Regional Winners
2011 Regional Chairman's Award
2012 Regional Winners
2013 Regional Chairman's Award
Unread 11-01-2013, 21:41
I agree, it sounds like the cRIO is using an older version of the firmware. Use the imaging tool to update and format it.
The DS will tell you the version on the controller as will the imaging tool.
Greg McKaskle
