Go to Post A learning experience. Or something positive like that. - NorviewsVeteran [more]
Unread 13-01-2013, 20:46
xSAWxBLADEx's Avatar
xSAWxBLADEx xSAWxBLADEx is offline
DaBears til 13 turned Free Agent 14
AKA: Michael Hawley
no team (Free Agent)
Team Role: Scout
xSAWxBLADEx will become famous soon enoughxSAWxBLADEx will become famous soon enough
Send a message via MSN to xSAWxBLADEx
Re: How to attach a metal hook to a timing belt.
Originally Posted by Jeffy View Post
+1. Or I found a glue called "E6000". I think it might have a bit more strength, but stays flexible too.
I use E6000 at work. It has a little more strength then "Super Glue", but not much more.
2006-Palmetto Regional Champions with 11 and 1251 (MORT, TIGERS, BEARS, O MY!)
2007-Pittsburgh Regional Champions with 123 and 337 / Detroit Regional Champions with 123 and 903
2009-Traverse City District Competition Champions with 85 and 2645 / Traverse City District Competition Chairman's Award / Michigan State Championship Finalists with 1918 and 904 / Championship Finalist with 217 and 68
2013-Grand Blanc District Competition Champions with 33 and 1718
Unread 13-01-2013, 16:19
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
Team Role: Coach
Rookie Year: 2010
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
If you still like belts, what's stopping you from grooving the pulley to allow a fastener to pass through? All it takes is a lathe and a little patience. You shouldn't need the full width of the pulley to grip the belt if it is just lifting the weight of a frisbee.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 13-01-2013, 17:51
mdiradoorian mdiradoorian is offline
FIRST Alum
AKA: Matthew
FRC #0696 (CircuitBreakers)
Rookie Year: 2010
mdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant future
Here is the link for the glue and thank you http://www.michaels.com/E-6000%C2%AE...efault,pd.html
that is true, however I want a system to be simple, easy to make and easy to repair if it breaks.
Unread 13-01-2013, 18:01
Team Role: Coach
Rookie Year: 2010
What isn't simple to make? If you have access to a lathe, simply chuck up a pulley and turn a groove. If you don't, a student can achieve the same results (although a little less pretty) with a file and some spare time.
What isn't simple to repair? You would effectively cut the teeth off the pulley in the center. So if you used a fastener with a .25 head on it, cut a quarter inch groove in the middle of the pulley teeth. The only thing that might fail would be a fastener and those are pretty easy to come by.
Andrew Basse
Unread 13-01-2013, 18:49
FIRST Alum
AKA: Matthew
Rookie Year: 2010
Oh by the way putting a fastener in the middle of a timing belt would increase the chances of of the belt breaking even if i were to make a groove in the middle of the pulley. The reason how I know is that I have tried. By having a belt you need tension and tension stretches to belt and when you stretch the belt with a hole in the middle of it increases the chances of it tearing.
Unread 13-01-2013, 18:57
Team Role: Coach
Rookie Year: 2010
A belt tearing is very dependent on the stress levels we are talking about. I'd hope hat there aren't a lot of forces involved in a frisbee conveyor, otherwise I would question the overall design.
Andrew Basse
Unread 13-01-2013, 19:27
Lisa Perez's Avatar
Lisa Perez Lisa Perez is offline
FRC #0573 (Mech Warriors)
Lisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond repute
An alternative to lathing a slot in the pulley would be to obtain a non-flanged pulley whose width is smaller than the belt width. You could then fasten the hooks to the edges of the belts. You would, however, have to consider how to keep the belt centered on that non-flanged pulley.
Event Coordinator - Center Line District Event
Volunteer Coordinator - Michigan State Championship
Lead Mentor - Team 573, Mech Warriors
Former Mentor - Team 830, Rat Pack and Team 3182, Athena's Warriors
Proud Alumna - Team 573, Mech Warriors and Team 1, Juggernauts
