Go to Post the hardest task this year is the same as every other year: getting the engineers out of the crate so you can close it up and the FedEx guy can haul it away! - KenWittlief [more]
Thread Tools Rating: Thread Rating: 11 votes, 4.82 average. Display Modes
Unread 12-01-2013, 14:06
ILikePizza555's Avatar
ILikePizza555 ILikePizza555 is offline
AKA: Isaac Avram
FRC #2761 (CN Ironhorse)
Rookie Year: 2012
ILikePizza555 is an unknown quantity at this point
cRIO imaging tool hangs on "Rebooting cRIO"
Hi,
I've been trying to image our cRIO II with the imaging tool, but evertime I do it, It always gets stuck on "Rebooting cRIO."
I have the latest imaging tool (2013.1.10) and I have tried EVERYTHING. Safe-mode, direct Ethernet connect, direct crossover connection, connecting through the d-link, changing my ip between 10.27.61.5 and 10.27.61.6, and changing the subnet masks between 255.255.255.0 and 255.0.0.0. But each time I get the same result:
It gets stuck on "Rebooting cRIO" and all I get see is the little User1 light blinking rapidly.
Any help?
Edit: I opened up wireshark to see if it was accually doing something, since nothing seemed to be happing. Then, I found out that this happens everytime I open up the imaging tool or press "Apply":
So, it doesn't login with the right password?
PONIES ARE STOOPID MAGIK -Heavy
