Go to Post I believe in my students, I encourage them to fail in their endeavors to find the best formula. There is valuation in failure. - Chief Hedgehog [more]
Unread 12-01-2013, 14:23
Team3763 Adam Team3763 Adam is offline
Lead Programmer
FRC #3763 (4H WildCards)
Rookie Year: 2010
Team3763 Adam can only hope to improve
(URGENT) No clue where to start with 2013 LabVIEW
Migrating from 2011 (2012) LabVIEW from last year, to this year's 2012 (2013) hasn't been...easy.
This past year, as most of you know, when you made a new cRIO project, it supplied all the .vis for Begin, Teleop, Auto, Finish, Disable, etc. With this year's version of LabVIEW 2012, I cannot find where all of these VIs are. Let alone find a proper cRIO project to start with. Do I have to code one myself from scratch or am I missing something?
Basically I'm needing to know where to start with LabVIEW 2012 (2013).
Best of luck,
Adam.
Unread 12-01-2013, 14:33
Re: (URGENT) No clue where to start with 2013 LabVIEW
Does your Getting Started window have FRC 2013 at the top of it? Does it have a Tutorials buttons, etc? If not, be sure to install the LabVIEW Update located here. https://decibel.ni.com/content/docs/DOC-26315
These and many other helpful resources are on ni.com/frc.
Greg McKaskle
Unread 12-01-2013, 14:38
Lead Programmer
Rookie Year: 2010
I opened LabVIEW and it says LabVIEW 2012 and has 2 parts; Create project and Open project. The previous version had Projects, Tutorials, Utilities, and Support tabs off to the left. This version doesn't.
Unread 12-01-2013, 14:41
So did you already install the updates?
I would love to have everything on the DVD in the kit of parts, but the logistics are that the code for the DVD is frozen many months ago, around the time the beta test was just starting. This means that the VIs that make up the Getting Started window and WPILib and examples has to be downloaded later, in the update. The same is true of the imaging tool, DS, etc.
Greg McKaskle
Unread 12-01-2013, 14:49
Lead Programmer
Rookie Year: 2010
I'm downloading all the updates in the link you provided prior. Hopefully this is the key to moving forward.
Unread 13-01-2013, 23:41
Lead Programmer
Rookie Year: 2010
So, I downloaded all the needed files from the link provided, and viola! We're back in business. It now displays 2013 FRC LabVIEW. Many, many, many thanks to your MUCH NEEDED help. Now I can teach my teammates and move forward with this year's competition! I'll make sure to make a note of your name as credit
3763 Adam.
Unread 14-01-2013, 20:51
team3039 team3039 is offline
FRC #3039
team3039 is an unknown quantity at this point
Have to mention this one: http://wpilib.screenstepslive.com/s/...abview-program
Great website from the creators of the WPI library.
