Go to Post When you find yourself saying multiple times at one regional "...never coding at 1am in the hotel again... ...never again..." - BigJ [more]
Unread 12-01-2013, 19:37
cosmicexplorer cosmicexplorer is offline
FRC #1389
cosmicexplorer is an unknown quantity at this point
horizontal bar clamping device
For pyramid climbing: I'm considering a way to rotate our robot upwards off the ground by clamping onto the horizontal bar and swinging our robot body up, like this poorly drawn diagram.
Two questions:
1) What kind of clamp would be able to stay in place without slipping? Is it COTS or can we build it ourselves?
2) Is there a way we could make the clamp not require motorization (because motors are heavy and draw power)? For the motor that would be rotating our robot body upwards, would a window motor work on its own? Would two? Or would we have to have some intense gearing? We expect our robot will be around 100 pounds at the very least, weight is always an issue with our team.
Unread 12-01-2013, 19:44
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: horizontal bar clamping device
Window motors would be hopeless unless you want to spend all day climbing the pyramid. You want to use a CIM with a really high gear ratio.
Unread 12-01-2013, 23:16
DonRotolo's Avatar
Back to humble
FRC #0832
Preventing the clamp from rotating on the horizontal bar would be very difficult in my opinion. Especially without damaging the finish of the bar.
Here is a different idea: what if your clamp were to clamp onto the bar and the robot were to spin sideways, in the plane of the pyramid's face? If the clamp were several inches wide and had a soft grippy foam surface, it might not spin around The axis but lift the robot into the air, kind of like what team 33 did in 2010 breakaway.
Unread 12-01-2013, 23:36
Kevin Selavko's Avatar
Kevin Selavko Kevin Selavko is offline
AKA: Voltonless
FRC #3260 (SHARP)
Team Role: Electrical
Kevin Selavko is on a distinguished road
Also you will have to be able to remove the clamp unpowered.
Team SHARP
Pittsburgh Regional Champions 2014
Vex Pittsburgh Excellence Award 2014
Vex Pittsburgh Champions 2014
Vex Maryland Champions 2014
Pittsburgh Regional Finalists 2013
Buckeye Regional Finalists 2013
Unread 13-01-2013, 00:44
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Team Role: Leadership
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
Think monkey wrench
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
Unread 13-01-2013, 00:45
FRC #1389
At first when reading that I thought you meant going up the diagonal, but what you propose is actually really interesting. It also means we could do it with just four or so motors. Making the gripping claws wider would mean we'd be relying on the grippiness of our claw, too. If our robot is short enough, we might be able to swing up and grasp onto the third horizontal bar with two clamps. We'd have to be able to dislodge it unpowered (thanks Kevin), but there's probably a way to get around that.
Hm. Definitely something to prototype. Thanks!
Unread 13-01-2013, 11:27
JPC JPC is offline
AKA: JP Christiansen
None #0302 (The Dragons)
JPC is an unknown quantity at this point
We did some concept packaging of this idea. We struggled with the robot package running into the pyramid and getting the second clamp on the second bar before moving on to other ideas.... Just want to help you avoid or design around the issues we saw if you go this way.
JP Christiansen
Unread 13-01-2013, 14:06
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Grabbing a corner gusset may be better than grabbing a rung. Also, think bear trap for your clamps if you don't want to use motors.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
