Go to Post Basically, just because you CAN do something doesn't mean you should and being savvy enough doesn't entitle you to being above the law. - Greg Needel [more]
Go Back   Chief Delphi > Technical > CAD
Unread 12-01-2013, 22:33
1683cadder 1683cadder is offline
FRC #1683 (Techno Titans)
Team Role: CAD
Rookie Year: 2012
1683cadder is on a distinguished road
Content Center
When I use the bolted connection accelerator, there is nothing to choose from. Where can I download the content center for 2010?
Unread 13-01-2013, 20:58
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Re: Content Center
Content Center is available on the application DVD or in the download from the Student Community.
There are a couple reasons why it may not be available.
1. It was not installed when the application was installed. Have you been able to use it in the same machine before?
3. There may be an issue with your project file.
Answer question 1 and we can go from there.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 14-01-2013, 20:28
Team Role: CAD
Rookie Year: 2012
Re: Content Center
This is my first time using it, so maybe it wasn't installed.
