Go to Post You don't always get what you pay for, but you hardly ever get what you don't pay for. - MrForbes [more]
Unread 13-01-2013, 01:13
Kusha's Avatar
Kusha Kusha is offline
Crimpin' ain't easy
AKA: Kusha Gharahi
no team (Looking for a team)
Rookie Year: 2010
Kusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the rough
2 wheels vs 1 wheel in a linear shooter
What are the advantages to having two wheels in a linear shooter? Disadvantages?
“Be the change that you wish to see in the world.”
― Mahatma Gandhi
Unread 13-01-2013, 01:16
hugo3337's Avatar
hugo3337 hugo3337 is offline
FRC #3753 (BulahBots!)
Rookie Year: 2010
hugo3337 is on a distinguished road
Re: 2 wheels vs 1 wheel in a linear shooter
your frisbee has better momentum with two wheels. Unless your motor is good enough that it can take care of that. Also to make sure that after you shoot it reaches top speed faster with two since when using only one youre asking your motor to do more work. Hope this helps!
the down side is that youre using an extra motor and adding some more weight.
Unread 13-01-2013, 01:20
Kusha's Avatar
Crimpin' ain't easy
AKA: Kusha Gharahi
Rookie Year: 2010
Does it have better momentum because of the increased contact? And wouldn't the frisbee have the same speed of the last motor?
― Mahatma Gandhi
Unread 13-01-2013, 01:26
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
Team Role: Leadership
Rookie Year: 2012
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Our understanding is the additional contact time results in higher speed.
With one wheel, the frisbee just touches the wheel for a fraction of a second. Two wheels allow for a preliminary speed-up followed by a final acceleration and fly-out of the shooter.
A circular pathway shooter allows vast amounts of contact but has its own flaws. It seems like the linear shooter compensates for this lack of contact by having two wheels.
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
Unread 13-01-2013, 01:33
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
Additional contact helps as does avoiding slippage but I think it is more about the relative rotation. The max velocity you can impart with one wheel is half the tangential velocity (because the frisbee is also rotating in proportion to the wheel's rotation and in the opposite direction). With two wheels you can approach the tangential velocity.
You want the firsbee to spin for stability so if using 2 wheels I think one might try running the two wheels at slightly different speeds.
HTH
Fast, cheap or working - pick any two!
Unread 13-01-2013, 09:29
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
I believe the 2 wheels we are talking about here are on the same side of the frisbee (i.e. both wheels are opposite the guide rail).
With 2 wheels, the maximum frisbee speed is still half the wheel tangential velocity.
Name:	2 wheel linear.jpg
Unread 13-01-2013, 11:46
ctccromer's Avatar
ctccromer ctccromer is offline
Animus
AKA: Tucker Campbell
FRC #3753 (Bulah Bots)
Rookie Year: 2012
ctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to all
Just out of curiosity, has anyone tried using two wheels with one on each side of the shooter? My team prototyped the common build with 2 wheels on the same side, but I'm curious how the other 2 wheel build would work
Team 3753 BulahBots
Unread 13-01-2013, 13:34
pleaseignore's Avatar
pleaseignore pleaseignore is offline
Former Member
AKA: Andrew Hagen
FRC #2883 (Fighting Rednecks Engineering and Design)
Rookie Year: 2013
pleaseignore is an unknown quantity at this point
What's wrong with a circular path?
Unread 13-01-2013, 13:39
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Search is your friend. Discussed at length in that thread.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 13-01-2013, 13:48
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Frisbees, in general, work by spinning, so having wheels on only one side is just a more elegant and efficient way of imparting spin.
Here's another reason why two wheels is theoretically better than one: Let's say you spin your one wheeled shooter up to a set speed. When the Frisbee contacts it, momentum will be lost, so the Frisbee will leave at less than half the original set speed. The motor can compensate by accelerating the wheel back to its original speed, but more likely than not, the Frisbee will already be gone by then. Two wheels allows you to "sacrifice" the first wheel's momentum so that you don't have as much of a momentum loss at the final wheel.
This is also why a curved track or a belt on a linear track is nice for hurling discs because there is a long period of contact during which the flywheel/Frisbee system recovers any lost momentum.
Of course, I may be unintentionally exaggerating - I have no idea whether the loss of momentum is actually consequential, since I haven't done any of the math.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 13-01-2013, 21:03
Andrew Zeller's Avatar
Andrew Zeller Andrew Zeller is offline
Mechanical Engineering at UA
FRC #1716 (Redbird Robotics)
Rookie Year: 2010
Andrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura about
I also followed your math here:
It translates into approx 21 mph, assuming no slipping.
3600 rpm / 60 min/sec = 60 rev/sec
60 rev/sec * pi*4/12 ft/rev = 62.8 ft/sec
62.8 ft/sec / 2 = 31.4 ft/sec
31.4 ft/sec * 3600 sec/hour / 5280 ft/mile = 21.4 mph
I understand that the rotation of the frisbee as it contacts the wheel causes less than its full velocity to be transferred in an ideal situation, however why is it that the maximum exit velocity of the frisbee will theoretically be one half that of the tangential velocity of the wheel?
FIRST ROBOTICS TEAM 1716 Redbird Robotics
2012 Wisconsin Regional Judges Award
2012 Wisconsin Regional Quarterfinalists
http://www.frc1716.org/
Unread 13-01-2013, 21:23
Ether's Avatar
Rookie Year: 1969
Think of a car traveling down the highway at 60 mph.
The geometrical center of each tire is traveling at 60 mph.
At any instant in time, the bottom of each tire is traveling at 0 mph, and the top of each tire is traveling at 120 mph.
It's the same with the frisbee.
Unread 13-01-2013, 21:58
Rookie Year: 2010
Makes sense - thanks for the explanation.
Unread 15-01-2013, 12:11
Ether's Avatar
Rookie Year: 1969
Oh - sorry! Why would anyone want to do that?
To allow for more contact time with the frisbee so the acceleration can be distributed over 2 wheels instead of just 1, to minimize slipping and improve final exit speed and consistency.
Lots of discussion going on about this in this thread, and other threads.
  #15   Spotlight this post!
Unread 15-01-2013, 22:00
Squeakypig's Avatar
Squeakypig Squeakypig is offline
AKA: Mike Coyle
FRC #2851 (Crevolution)
Squeakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond repute
https://www.youtube.com/watch?v=ARUhI8Qob5w
This is our prototype 1 wheel shooter. We made a 2-wheel shooter but the video we have of it is poor in quality. We will post a new video of the 2-wheel in the very near future.
Here is the video anyways: http://www.youtube.com/watch?v=EYpbyVbMbD8
