Go to Post GP is asking for something then having twenty people answer graciously. - synth3tk [more]
Unread 13-01-2013, 01:43
William Kunkel William Kunkel is offline
Programming Lead
AKA: Kunkel
FRC #0422 (Mech Tech Dragons)
Rookie Year: 2011
William Kunkel is an unknown quantity at this point
Unit Tests & Test-Driven Development
Does anyone know of a sane way to write unit tests for robot code? I'd prefer to have a test-driven development cycle for our code, but I can't think of a good way to implement it for this kind of programming. There's a test harness project on FirstForge here, but it seems to be a dead project. Any ideas?
Unread 13-01-2013, 02:22
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #1418 (), FRC #1973, FRC #4796, FRC #6367 ()
virtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant future
Re: Unit Tests & Test-Driven Development
Revive the project
Maintainer of RobotPy - Python for FRC
Creator of pyfrc (Robot Simulator + utilities for Python) and pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript)
2017 Season: Teams #1973, #4796, #6369
Team #1418 (remote mentor): Newton Quarterfinalists, 2016 Chesapeake District Champion, 2x Innovation in Control award, 2x district event winner
Team #1418: 2015 DC Regional Innovation In Control Award, #2 seed; 2014 VA Industrial Design Award; 2014 Finalists in DC & VA
Team #2423: 2012 & 2013 Boston Regional Innovation in Control Award
Resources: FIRSTWiki (relaunched!) | My Software Stuff
Unread 13-01-2013, 11:03
Spaghetti's Avatar
Spaghetti Spaghetti is offline
FRC #0488 (XBot)
Rookie Year: 2011
Spaghetti is an unknown quantity at this point
Curious if short of emulating the robot like the test-harness project was trying for, does anyone have a nice flow for unit testing bits of logic sans crio that have no robot dependencies?
Unread 13-01-2013, 11:12
Programming Lead
AKA: Kunkel
Rookie Year: 2011
I'd love to revive the project, but I don't think it's appropriate to do during build season.
Unread 14-01-2013, 13:08
virtuald's Avatar
RobotPy Guy
What we created for RobotPy users (python interpreter for cRio) is a library called fake-wpilib, which has bare implementations of most of the WPILib objects. You setup some hooks, import the robot code, and call StartCompetition(), and your unit tests have access to see/control everything.
We have implemented separately a tk-based program that allows our students to run their python robot code in a simulator of sorts, and they can drive the robot around and use sensors and such.
If I was re-implementing the test harness again for C++, this is probably how I would go about it. It seems like someone could create a script that could parse the C++ code and automatically create functional shells from that. Tools like SWIG and SIP sorta do that sort of thing, you would just need a mechanism to map function inputs to public variables.
Unread 14-01-2013, 13:43
Chris Hibner's Avatar Unsung FIRST Hero
Chris Hibner Chris Hibner is offline
Eschewing Obfuscation Since 1990
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Rookie Year: 1997
Chris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond repute
The simplest way is to design your software units for test. What I mean is this: do NOT make any calls to the WPI library from within your unit. Make all calls to WPI library in a wrapper function.
For example:
Code:
void periodic_10ms_task(void)
    armAngle = WPI_readEncoder(ARM_ENCODER);
    armLimit = WPI_readDIO(ARM_LIMIT_SWITCH);
    armOutput = controlArm(armAngle, armLimit);
    WPI_setPWM(armOutput);
Before anyone complains: I don't really know what the WPI library function name are - the above names are made up (we use LabVIEW).
Now you can test you controlArm() function as a unit on a PC using MS VisualC++ Express.
An ounce of perception is worth a pound of obscure.
