Go to Post "Your really pretty and I like your bot" - prettycolors91 [more]
Unread 13-01-2013, 18:54
iggle3 iggle3 is offline
FRC #0900
iggle3 is an unknown quantity at this point
Disks landing after contact with the wall
My team is considering the conundrum of whether it will be worth it to flip the disks after picking them up off the field. I decided that the most important thing to consider is how many of the disks that have been thrown will be upside down. So this is my question. Will a disk making contact with the wall at high speeds be more likely to land label up or down?
Unread 13-01-2013, 19:04
AlecMataloni AlecMataloni is offline
Excellence is Bliss
FRC #0111 (WildStang)
AlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond repute
Re: Disks landing after contact with the wall
Sounds like something to test with a shooter prototype! Maybe your team should try experimenting, and then you could report your findings to the CD community. I'm sure many people would appreciate your work/findings.
Unread 13-01-2013, 19:11
Tom Bishop's Avatar
Tom Bishop Tom Bishop is offline
FRC #0832 (Oscar)
Team Role: Coach
Tom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant future
It has been my experience (and I have pretty extensive experience with Frisbees, misspent youth and all that) that most Frisbees land right side up when the are thrown, even when thrown at high angles. The major exception is when you throw and it rolls, or when you throw an overhand tomahawk, then they they tend to come to rest upside down.
I also spent some time throwing at a wall and all of the throws landed up right. Those Frisbees have quite a bit of bounce in them.
Now mixing robots and Frisbees might change things, but I think the whole upside down Frisbee deal is a bit overblown. If its upside down just don't pick it up!
Unread 13-01-2013, 19:17
rwkling1's Avatar
rwkling1 rwkling1 is offline
FRC #2977 (Sir Lancer Bots)
Team Role: Leadership
Rookie Year: 2011
rwkling1 has a spectacular aura aboutrwkling1 has a spectacular aura about
i don't think it's worth your teams time to try to flip the disks, if you're going to pick them up off the ground, concentrate on the ones upside up
Unread 13-01-2013, 19:22
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
I can tell what's going to make me shake my head the most this year is watching teams foolishly wrangle with a single disc for 30 seconds or more when it's propped against the wall. Remember efficiency is the key.
Unread 13-01-2013, 19:59
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
Team Role: Teacher
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
I don't have scientific data, but We we play frisbee football, the frisbees almost never land upside down, even after bouncing off walls...
Faridodin "Fredi" Lajvardi KD7WKD
Unread 13-01-2013, 20:14
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder
AKA: noops
FRC #1648 (G3 Robotics)
Team Role: Team Spirit / Cheering
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
This. If it's upside down, and unless finding another right side up disc is going to take more time than picking up and handling the upside down frisbee, it's not worth it.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
RIT Graduate Student, CompE
Unread 14-01-2013, 19:50
mbushroe mbushroe is offline
FRC #2840
mbushroe is an unknown quantity at this point
I did actually spend some time throwing a Frisbee at the wall. 11-0 it fell right side up, which was also the way I was throwing it. However, that was hand thrown, which means spinning. If you use some kind of ejector that does not impart spin, it will be more likely to fall the other way. But I would guess that between 75% and 90% of the loose Frisbees on the floor will be right side up, unless some team decided to shoot them up-side-down.
Mike
Unread 14-01-2013, 21:55
smclean1969 smclean1969 is offline
FRC #3512
smclean1969 is an unknown quantity at this point
we ran a very simple test where we just threw the disks against a concrete wall. 90% of the disks landed right side up. The only ones that didn't land right side up were thrown at highly inclined angles that are unlikely to be done during the competition.
Scott McLean
FIRST Team 3512, the Spartatroniks
Team role: mentor
2011: Highest Rookie Seed and Rookie Inspiration Award Long Beach Competition
2012: Winner Los Angeles Regional -- w/ Team 987 and Team 1717
2013: Finalist Los Angeles Regional -- w/ Team 599 and Team 981; Engineering Excellence
2015: Entrepreneurship Award - Ventura Regional
Unread 15-01-2013, 00:28
stryker0603 stryker0603 is offline
AKA: Jordan Smith
FRC #0314 (Megatron Oracles)
stryker0603 will become famous soon enoughstryker0603 will become famous soon enough
Over the past weekend, we estimated we shot the disks around 200 times. The only times that the discs landed upside down was after a crazy roll and hitting a wall. We had it happen maybe 5 times so I honestly think that it won't be an issue at all.
