Go to Post Why do FIRSTers think we're better? ...because we hold values like honesty, integrity, and intelligence dear... - Redneck [more]
Unread 13-01-2013, 21:55
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
Team Role: Leadership
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Lead screws
We're looking at using lead screws to adjust the angle on our shooter. Like many teams did with their hoods last year. What products work well, and which robots implemented them especially well. We're specifically interested in how teams attached a KoP motor to a lead screw.
FRC Team 4334
2012 - Archimedes Champions, IRI Champions
2013 - Western Canadian Regional Winner, Galileo Quarter-Finalilst
Unread 13-01-2013, 22:30
Kevin Sevcik's Avatar
Kevin Sevcik Kevin Sevcik is online now
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: Lead screws
We used a lead screw in a telescoping arm in 2011. The easiest way to attach a KoP motor to a leadscrew is to buy a leadscrew the same diameter as the output shaft of your gearbox and use a rigid clamp-style coupler to attach the two together.
Next easiest is to use a lathe to turn the leadscrew down to the same diameter as your gearbox shaft and then use a clamping coupler.
Least easy is if you can't afford to have the length of the gearbox+motor sticking out the end of your leadscrew and you want a sprocket or pulley on there instead. Then you need to do a true end-prep on the end of the leadscrew, which involves turning and end down so you have (working from the end of the screw inwards): an output shaft sized for your sprocket/pulley, a thread for your lock nut, and a bearing seat for one or two bearings. And then you need a bearing block to house those bearings. Probably you're not actually interested in this option, so go with one of the first two.
Unread 13-01-2013, 22:33
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Re: Lead screws
Considering that ATA has more Lathes than some teams have students...
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
