Go to Post At this point I think I've absorbed more aluminum into my blood than the iron that was already there. - hectorcastillo [more]
Unread 17-01-2013, 02:37
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Re: Is Anyone Successfully Shooting with a Belt?
NOTE TYPO IN ABOVE WRITE-UP -- Belt urethane thickness should be <.100" for smaller pulleys and better convex shaping to curved edge of disk.
Basic dual belt concept with pivot bar idlers fixed => i.e without any spring loaded swing arms added between idlers & pivot bars.
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
Unread 14-01-2013, 12:53
ecchorobotics's Avatar
ecchorobotics ecchorobotics is offline
Eric Scardelli
AKA: Eric S
FRC #0075 (RoboRaiders)
Team Role: CAD
ecchorobotics has a spectacular aura aboutecchorobotics has a spectacular aura aboutecchorobotics has a spectacular aura about
Team 75 succssfully used a belted shooter last year. Its performance is highly comperable to the one wheel+curved wall design, although some aspects proved to be serious problems. Things like belt inefficieny/stretching/grip/wear and overal mechanism complexity made the shooter somewhat troublesome. However, there is no "physics" reason (that I can come up with at least) to say that a shooter with belts is any less functional than a shooter with a curved wall and one wheel. The principle is the acceleration period, which depends on the required change in momentum of the projectile. The larger the change in momentum is, the longer the wall or belt is required to be to reach the target speed.
I should also add that a curved wall and wheel is no differet in terms of friction from a belt and a wall; using belts is simply "unrolling" the wheel into a flat surface. I'll try to explain as best I can by saying that 2*pi*r would be the belt+wall length required to achieve the same performance as a wheel with that same r plus a curved wall. Unless you take into account other factors such as ceptripetal force and angular acceleration, then things change slightly.
Unread 14-01-2013, 12:56
velcro velcro is offline
FRC #0177
Rookie Year: 2012
velcro is an unknown quantity at this point
It's good to know the principle works with the foam balls from last year, but I was hoping to find someone who made it work with frisbees. If nobody has done it yet, there could be unknown issues that make it more difficult than it looks.
